f**k you guys, Ricciardo is a mad kunt. I've even worn a themed tie for the occasion
All I see is a corporate wanker with a tie clip.
What happened to keeping it real? City office politics must be a headf**k.
#nohate
Needs more singlets #fiifo
I was at a family gathering when someone just got back from thailand, giving out gifts to people.
"You better not have gotten me a Bintang singlet"
"Nah"
"... Or a chang singlet"
"Nah"
*opens gift with singha singlet inside*
ead lololol
  • Like 3
#nohate
I dress this way cos I like fashion... not a whole lot of office politics in the public service
Come at me you bogan
how about a turbo tie:
http://blipshift.com/products/turbo-tie
or a shifter tie:
http://blipshift.com/products/gearshift-tie
http://blipshift.com/collections/accessories
I've made the call that I refuse to wear a tie...unless job interview.
or a shifter tie:
Subtle. They're not bad. But Db5 >
Exactly. If you have nice things they will probably get stolen no matter where you live.
Unless you live where I do and had a "friendly" dog
lol:
Guy Goes To Mexico To Kill Himself, Spends Week Doing Coke And Banging Hookers, Decides To Keep Living
http://totalfratmove.com/guy-goes-to-mexico-to-kill-himself-spends-week-doing-coke-and-banging-hookers-decides-to-keep-living/
Hahaha saw that a while ago, would do it just for the sake of doing it
haha nothing wrong with fashion.
discussion point: if a workplace culture condones the use of designer tie-clips, this may allude to the point that business-attire could be a factor on the judgement of colleauges. (excluding colleagues who deal with external clients etc)
May not be an issue in your space as mentioned but could be in other places.
Have always worn company issued uniforms for both Site & office along so never had the issue.
However where ones uniform is prescribed, the stand-out factor is usually the flashiest watch.
then this is the watch you need:
http://www.hsjewellers.com.au/blogs/news/15499832-pulsar-v8-supercars-limited-edition-watch
Meh... casual workplace here... I just wear neat casual... Jeans and a nice top or jumper... Shirt if I feel like it
There's nothing customer facing out this office at all so that helps
Can this be used to time how long a freshly built SR20 will last during a track day?
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
