Pics? And price?
no pics yet.
drove it. nice zippy car, 370GT
Surprisingly small! its like one of those audi sport back things.
feels punchy. uncle things its a monster. haha
he paid in the low 30s landed and complied
Alvin may like to correct me, but I don't think e85 goes off / loses it's octane in tanks as fast as say 98 would.
They would be sealed to prevent water build up, and alcohol/ethanol doesn't really go off over time?
(in some cases improves!)
assuming perfect seal, same same, the problem with etOH based fuels is it absorbs water, and above a certain percentage, it splits. not funny so yeah dont use old fuel.
with petrol, octane falls and the additives gum up in the presence of oxygen. much of the same really.
  • Like 1
that's quiet interesting when according to the Gov most petrol stations have water in their tanks already
http://www.fairtrading.nsw.gov.au/ftw/Consumers/Buying_goods/Petrol.page#Water_in_petrol
so one has to hope these are sealed a bit better.
Didn't you have meisters Pat? These look the same?
Still have the meisters; look similar but different
custom 2pc 32 GTR rims, stepped to 17"
EXACTLY what I have been trying to make Mohsen get.
so f**king boss
+1
I want but custom :(
2 cool to walk.
birds theres a built 26, ready for a head and some hangons on facey for 4500
In qld? If so it's on eBay too
Not a fan of the gear he's used in it, $350 forged pistons etc.
$4.5k for just a built bottom ends seems alot
yes, and i'd want someone to go over it before i whack it in the car... not gonna trust nobody. especially for RB26, when if a hairdresser does a bad job it not only makes a vocal complaint but then pulls out a gun and shoots everybody inside.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
