Alternatively... as happens... they'll be crashed within a month and they'll send you pictures, thinking you want to know they've destroyed all your hard work, for some stupid reason
Leigh
Bit on the pricey side but everything's done for ya
http://www.sau.com.au/forums/topic/453579-1995-r33-gtr-vspec/#entry7474454
If you consider it's 10k cheaper than the cheapest security guard, it's kind of good value
Leigh
Can buy a built racepace GTR for that! No thanks jeffrey!
Leigh
Nahh dat cop rape again, don't want those feels.
All+of+dem+feels+_58ef1609b2f953f028b9e5
Not sure how I'd go back with a 16 year difference too
Edited by UNR33L
Buy standardish one, put -9s or -5s on it. Run E85 and make 370+kw. You've spent under 25k easy and can still afford to keep your Ford!
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
