Saw Aston Martin / Jag looking car accelerate rapidly out of driveway in Wantirna...closer inspection it's a Tesla Model S 85
Didn't get a chance to run him, but managed to leave him behind as he followed me out of a slip lane. Silent as a dead man
Keep an eye out for him Leigh lol
LOL, Tesla is pretty deceiving looking thing, In Slovenia, one went past the bus I was in, the car went pretty fast even though the bus was travellign 120km/h.
Thought it was a Jaguar at the first but part of me say it isn't, until I arrived Ljubljana and I'd saw one parked next to charging point, and gave it a closer look. God, it's good looking thing that, dare I say it's better looking than Jaguar XJ.
$88.40 x 12 = $1060/year
In the past 12 months I haven't paid for a single one of the 3 month long contact lenses I use (perhaps $500?), and about half of my new pair of glasses ($300 off) was covered. And I haven't even touched the physio extras that are thrown into my package.
So for me, a few hundred bucks out of my pocket to cover me if I had needed hospital, ambulance, etc is nothing...
Alex, that 18 month ahead surgery... would it be classified as a pre-existing condition? If so, you're gonna have a bad time.
r32 gtst was below the power:weight ratio.
Had a nice discussion with pettet as he tried to book me for high powered vehicle.
That's some old school defecting right there
He must have been only a cuntstable then
  • Like 1
Silent assassin, I'll show him what a real engine does
I had a good example N/A 33. made 125rwkw ish on that springy motors sau dyno day (roller dyno ZOMG)
GTSTs with the usual intercooler exhaust pod filter boost were making 175 ish?
125rwkw was enough to have fun at decas
(P85D)
515kw..(with very minimal drive train loss)
931 N·m
AWD..
11.6 1/4 when first out,
apparently have been reflashed to make them faster since.
just stick some better tyres on them and you got a 10 sec car..
Oh it was the top model one? dat shiz is 170k Then yeah that would make things a little more difficult, I still did an 11.6 though! :D
Maybe I'll put the extra 110k in my car and see what it does :P
Also unrelated Birds, gonna see if JB will match this price for the 70" Sony
https://www.ozbargain.com.au/node/182443
So you rate em?
Edited by UNR33L
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
