all these suspension arms are doing my head in...
so in the rear ill put in an adjustable camber arm and an adjustable traction rod. cant fit a castor rod.
but the front, can get castor arms, adjustable tension rods OR adjustable lower control arms (which includes a tension rod but doesnt look like the other tension rod in the pic).
Well yeah, the rear end doesn't have nor need castor.
i thought so too, but you can buy them for Z33 ??
that frustration when you spend a lot of time researching and arranging an informative post, go to post it, fails, press back, Ctrl+C.... 2mins later Ctrl+C something else and lose all the previous info.
I know dem feels... I just love watermelon so much...
My GTS-T is the best daily I've had. Occasionally wish it was more comfortable, but you can't have everything and the suspension/diff setup makes it such a confident and capable car to move around in - I feel safer driving it than brand new Commodores.
What's wrong with the BMW? Thought it was quite a sporty nimble car which would replace any skyline feels?
It's a great car and on paper it's the logical step up from a gts-t, but it just doesn't excite me a whole lot
I suspect with a few mods I'd come around, and the lack of police attention is refreshing, but Birds posting up links like that gets me weak in the knees. Could be the still painful theft f**king with my better judgment
Everyone who sells or loses their 33 misses it and that's all the proof I need that keeping is a good idea. That and my drives home from work are always over 9000
The fun factor that can't be bought in a new car - it's the character of a cheap and over-engineered powerhouse coupe from the 90s, back when cars weren't all about emissions, people gave no fks for economy, and we didn't try to stuff infinite amounts of de-skilling electronics into a car. Suspect it also has something to do with giving stick to a car worth less than 10k, so you don't care as much about breaking it...even though you never do, because 33 GTS-Ts are bulletproof*
*poles and thieves exempt
Y u do dis to me Birds :(
f**k I want it
Come on brah, that shit is chump change to your VWLBC status these days...whack third party fire and theft on it and it'll make you appreciate the Beamer more as a comfortable daily.
On a side note, I never appreciated my car more than when I had Alvin's auto as a daily driver. Daily and weekender is the way to go. You try to combine both and you're taking your compromise work chariot out for weekends = not the same.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
