I'm surprised you can find so many places you want to splash that much coin on...I mean I know you have to be quick to secure something good but do you actually see a dream place every week?
haha the inner-city location & low-car friendly driveway is what suits my current lifestyle.
The building itself is not a huge factor as anything is better than the plastic jayco cabin which I spend 70% of my current life in.
because FIFO
  • Like 1
I just spent the past month viewing shows on a Kogan TV, think it was about 55" and seemed to go alright... Looked like it ran some sort of android OS... though it was connected to a WDTV Live box, so I did all my playing vids through that instead of dealing with the TV itself...
Looked fine, the screen surface itself was quite reflective / glossy though, so it struggled a bit with clarity if all the lights were on in the room (even if the source wasn't directly reflected, it still was annoying)
At the end of the day, they're only 18" wheels so needs a bit of chunk to it (35 profile tyre). And it's the offset of the wheel, otherwise it would all fit under the guards without issue.
It's unfortunate, but there would be less dish and I can always reduce tyre width on the next set
We have a Kogan 55" HD 3d TV. Originally got as 2nd tv when we were in shepp, now is our main tv. If curtains are open lots of reflection but otherwise good, also have to run sound through our surround sound system as sound from tv was tinny. From memory we only paid around $600 around 3 years ago.
34gtr owners here are the worst at picking names
"VspecIInurgburgering"
"I gotta R34GR vspec II"
Defining themselves as cars they haven't even brought into the country yet. Just as bad as those mother forums who define themselves by their kids statistics
"Mumof3under5"
"Twosetsoftwins"
Bah. It's like the women try to outdo each other
  • Like 2
"Mumof3under5"
"Twosetsoftwins"
I dunno... I have a pretty bad name...
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
