*ahem* engineer whose specialisation is statistics checking in & you reference the lawyer
Lawyers are wordsmiths like myself and Hamish is Hamish; my apologies.
Please accept one student copy of SPSS as a goodwill offering.
B.Soc.Sc major in T tests
I was surprised when they changed the rules regarding to teachers from needing a diploma to a degree. Suddenly it's a much bigger commitment and time to become a teacher. Do you think it will increase the quality of teachers due to this?
Hmmm that one can sometimes take the input shaft with it, hopefully not yet and it's just on it's way out.
Outside chance, but can also be a clutch issue. Thrust bearing another slight possibility if it's rattling around on the input shaft retainer because it's slightly touching the pressure plate (a good way to test out this one is to put a small amount of pressure on the clutch pedal so that it presses the bearing firmly up against clutch, but doesn't engage the clutch...if noise disappears then it's probably this. Otherwise input shaft / spigot bearing is your culprit.
Might as well do rear main while you're there too.
Thrust bearing sounds very logical as I'm pretty sure the noise went away as I touched the clutch peddle.
Rear main was done with the new engine so should be good.
That's good news hopefully then
Just a semi box out job and hopefully it was just noisy and hasn't chewed away at the input shaft retainer, not that these are particularly expensive
  • Like 1
no
Yep
Can't guarantee that, but can guarantee there are heaps of lazy, uncommitted teachers who got through on a diploma and want a quick career in something they aren't particularly passionate about. Leesh has mentored quite a few teachers doing their student prac with her and it's always the diploma students who are the worst.
May mean a potential shortage in future, but yes I'd expect the quality to improve. Really no different logic from making med students do 6+ years of uni.
  • Like 1
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
