Only just got windows 7?
I run 3 screens at work as well gives me a headache sometimes lol
Dude... I'm one of the only people that have even got Win 7 lol
We still use CLI programs for our core tasks lol
Can you use anything as collateral besides equity in another property?
yes.. Personal Guarantees both supported (by real property) and non, Superannuation, Commercial premises, Cars, Boats, Planes, Taxi licenses... pretty much anything goes. Basically any tangible asset can be used as real security for a non regulated loan (consumer credit code) for a regulated loan, it's mostly just bricks and mortar / guarantees supported by bricks and mortar
Never gone portrait but tbh I often use windows.. as... windows. Full screening everything is kind of "too much" on a big screen. Can see why Portrait setups could work
but then, gaming
it works very well for what I do.
I have at least 10 programs running at all times and with my current setup have 6 of them on screen at all times.
you just need to have a big enough screen that it is wide enough when turned
At work:
Used to have Dual 22" Widescreen 1920x1080 - 16:9
Then had a Single 27" Widescreen 2560x1440 - 16:9
Now have a Single 29" UltraWidescreen 2560x1080 - 21:9
Ultra Wide lets me run two things side by side on the same monitor without squishing them, great for web dev etc...
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
