Yeah that would suck.
My track history is very poor.
Sandown: few sessions learning, snapped alternator belt cost 3 hours.
PI: 2 novice sessions, clutch and sandwich plate fails, 2 more sessions with no clutch on downshift.
Winton: 4-5 sessions, misfire developed.
Sandown: session one strips aluminium wheel nuts. Session 2 motor blows.
Sandown: smooth sailing. Scare Simon with smoke in cabin due to poor catch can setup.
Calder: car at tuners, run into problems, 0 sessions (least it drove home)
Winton: 1x 50% session, half a passenger lap then motor blows.
So yeah only ever had 1 full track day.
This is one reason people choose to do their racing on the street
  • Like 1
Or how about on a track day, where you ALMOST make it unscathed but think "Nah, one more session" .....
This.
Virtually every major injury I had in my skiing career was from "just 1 more run"
A well hidden winery in Yarra Valley is the last place I expected to run into Simon on the weekend
Then again
4:30pm, nearing the end of 6 hours worth of winery tours... Zig Zagged into Leesh and Birds, random.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
