So any-one know what working culture NAB is like?
about two weeks ago they forced win 7 onto all the desktops without telling staff overnight
then they had to restore crap from backups etc as people lost their data
1) poor strategy
2) poor comms
3) local data risk
4) v behind basic OS lifecycle schedule
but otherwise its probably good
i applied for a role there a few weeks ago
i know two other people who work there too
Unrelated:
Today switched from 50,000km old KU31 235s on the front and nearly bald R1R 265s on the rear to AD08 255s and AD08R 265s respectively.
Wow what a transformation. Those tyres are unbelievably good value for the $220 each they cost me. So much corner grip it's ridiculous; just turns in so well with the 255s up front. And finally a set of road tyres that can hold my 2nd gear all the way through - time to break out the G-tech again Leigh :P
Mind you, those KU31 are an incredibly hard wearing tyre. Still 40% tread left on these. Awesome value for a daily driver not pushing too much power.
Let me know how you go!
I wish we tried it again when I had NT05s on
1) poor strategy
2) poor comms
3) local data risk
interesting.
got an offer from them on friday.
not sure if I want to work at a bank tho.
Not if you pay enough money to AASA... There is NO WAY we'd be able to get insurance for 4 people in a car with no helmets and 30 on the track at a time... but they classify it as a Cruise Event and it's all fine apparently...
im glad people are doing it off the street (though i doubt many at the event save it for the track anyway), but surely there has to be a better way of holding such an event without damaging a racetrack.
Don't be silly, they've all practiced on racetracks while holding selfie sticks with go pros
1) poor strategy
2) poor comms
3) local data risk
Lol what a load of bullshit.
We have been rolling out win 7 for about 6 months now and it comes on a new laptop entirely. The few desktops that remain are still running XP.
Before moving to win 7 you get 11ty billion emails explaining exactly what to do, when and how.
Nab is great. Work/life balance is amazing and the culture is very strong. Most people stuck around for a LONG time. We do pay less than the other 3 however generally have higher bonuses
(Which kinda backfires when you we buy failing banks in England and have to provision hundreds of millions then cut bonuses lol)
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
