<3 my fumoto drain valve, still going strong after 5 years
Don't like your neighbour? Piss on his lawn with oil
Then sit there for 5 mins while you refill your car with oil and he asks what the f you're doing with a loud skyline on his property...
never really got those,
takes a few sec to remove a sump plug...
go have a beer and do something interesting.
come back few sec later sump plug back in place.
so it saves you a crush washer but in reality takes longer.
meh
still don;t trust a ripple strip vibrating one loose..
Realistically it takes a few minutes to get a spanner, reach under car and locate it to remove a plug and then have the oil piss all over it / bolt potentially fall in the pan, then replace the washer and clean the thread before putting it back in. I chuck a pan under the car and flick a switch. Mess free oil change anywhere anytime. It's handy for cleanly draining oil overfills too.
As a fastener it's no different to a sump plug so can't think ripple strips would hurt it any more than a sump plug. For that matter I doubt ripple strips would be any worse than some of the corrugated gravel roads I've driven on either. It's fun having a quick, hail-damaged daily driver and not caring too much what you drive it on.
Anyway, I don't really need to sell it on its merits, but I do think they are worth having if you do regular oil changes; might be one of those have to try it things.
  • Like 1
Hey guys, what's the difference between the 52T and 56T for the Garrett GT3076R? I'm looking at running two of them for my TT setup on zee 6L but Commodore blokes are useless with turbos.
Aiming for the 500rwkw mark if that's any help?
seriously doe, speak to Tao from hypergear and ask him about it.
He recently made 2 custom turbo's for Cat's LS1TT that makes huge power and they are right on the money
i'm going to take a wild stab that the 56T is larger
Cheers mate, I heard the 56T was larger too but not sure in what regards though? Is it to do with the impeller?
Also, if I'm not running Garretts, my tuner has reccomended Turbonetics. Haven't heard much about Turbonetics on SAU so thoughts?
waaaaahhhht
dont like the supercharger? whats re-sale on something like that... shiiiet
waaaaahhhht
I LOVE the supercharger! Very snappy and loads of fun. But I got over it and want to get back behind a turbo (two of them at least anyway).
Don't wanna discuss price but the buyer is gettting A LOT of bang for buck.
Put it this way: I chucked it up for sale on a couple Facey buy/sell pages and had 4 calls regarding it within 24 hours (2 were interstate, where 1 was prepared to drive down from NSW to pickup that weekend if I could get the blower off in time).
Pretty confident both would make your goal easily, on around 6psi most likely. ;)
  • Like 2
Sweet! But is there a spool difference between 52 and 56? (Like that's even a legitiment concern on a V8 LOL)
Only 6psi?! I was hoping to run about 15psi on E85 LOL
Guest
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
