Way to ensure rump is tender is to cook it well (duh) and then be sure to slice it AGAINST the grain. With most other cuts you can get away with it, but rump & oyster blade/skirt/hanger/flank you really can't
I found rump works best for tender medium almost medium well, but that all depends on fat streaks too
Don't know how to cut against grain, I remember you showing me in an isolated snow chalet but it was wasted on me
Can't sleep, Greg's cursed car will eat me.
Maybe you have a similar number of issues as anyone with a 400kw <8 cylinder car (post new engine) except:
1) they keep it on the down low
2) not daily driven
I'll show you, even a vegetarian knows how to cut against the grain.
2) not daily driven
Lol no...
You couldn't cut against the grain on the grainiest day of your life if you had an electrified grain cutting machine
Leeroy iracing half price renewal for 1 year 49.95 till end of June.. tempting but i'm not getting on there much these days
My brothers 33 gtst is STILL in some shop, been there for months and apparently all they've done is polish the plenum LOL
Apparently they need him to get a friend to bring their r33 in so they can compare whats in the engine bay or whats missing? wtf?
I keep telling him to sell the thing, problem after problem as it's been modded and screwed around with far too much now, he should of kept it at the reliable/responsive 250rwkw he had it at..
he's 28 on good money and been 'borrowing' mums car dafaqq
Edited by UNR33L
Lol no...
2) not daily driven
Well lets go over a few points here
1) I keep additional breakages on the down low
2) it's not daily driven, mainly due to fear.. and the fact I work 6 minutes from where I live, so it isn't even up to temp when getting here, and also fear
..it broke down about 1km from my house btw.. after doing 300+kms on the weekend..
Also the issue itself deserves mentioning...
How does one relay work but every other relay not work, when they share the exact same pins?
Car primes
crank car, got fuel pressure
start car, no fuel... until it runs for ~10 seconds then its fine
sure ok
Wire up a button to force the pump to pump, in the idea of holding it down until the car stops being retartded
this works, cool, but we're using a 30A supercheap relay
Put 70 back in. Same pins.
Problem different. Car won't run unless button is held in.
f**k it, whatever, use the normally closed option on the 70 relay to make the pump actually f**king pump all of the time even if the car is off, plug it in in the boot to go for a drive. Cool.
Until of course, that doesn't work anymore either
Car turns over
Fuel pump primes and is pumping, just stalled and refuses to start
No fuses blown
best idea so far is I've somehow blown a fuel line inside the fuel tank
Side note: I didn't need your tank Simon as, well, the issue was with the tank lid itself.
Guest
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
