f**k all y'all.
yeh now when I drive hers i just dont go into 6th anymore.
I had a job interview the other day and had to push it out of the parking spot.
I just said "because race car" and hoped it would be ok..
Im refusing to drive the thing now..
it doesnt engage reverse anymore.. at all.. it will go in but as soon as i start releasing the clutch it pops out and starts crunching..
Lol Aaron you pushing the car in and out of parking bays reminds me of a kid at school that bought a vs with no reverse. Would see him pushing it it 30 metres to get out of
The car park.
Ham and pat. Interesting.
Ill do some more research soon.
On another note, replaced GTR dash with my spare gtst dah, as well as the messed up dash surround(you were right about stock piling parts pat!)
The car park.
haha i should start up a r32 wrecker yard with the amount of spares i have around the house.
Didn't think the box would even allow that to happen...
What happened when you released the clutch in reverse at 100km/h?
He wouldn't have even got that far, just trying to put it in reverse hard enough would have ripped the teeth of his reverse idler gear. Car pretty much needs to be going backwards to get away with putting a moving car in reverse and even then it's tricky.
son of rajab knows why you wouldn't just wait until the car is stopped to select reverse.
ah f**k you alvin.. lol
but to answer your question yes. I was in zombie mode, 4am, just driven the missus 6spd rx8 for about 45 minutes.. got in to mine and was in the 6 speed habit.
lol ive nearly done that in the 34 after being used to the s15 6 speed
moh, throw inn another rb20... chuck on a 2535 or thereabouts and have ~230rwkw with a nearly 5000 rev powerband.
no engineering, no hastles, no modifications, hella fun and will cost you like $20 for the motor
And on top of that, I know Of the perfect hks 2535 setup for sale, with manifold, ex gate, and stock heatshield incl covers the whole setup.
Guest
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
