San Andreas; the game that was always fun.
Chucked in gta4 just the other night. Game engine was good but it just didn't have that fun replay value of San Andreas…
Although shotgunning drivers in the face is still pretty fun.
  • 5 months later...
looks like an exciting story for once! however, it also could be taking the 'setpiece' path and showing all the best parts through cutscene...
Also really keen to see if it FINALLY gets away from the all-missions-are-favours-for-people-you-dont-like-and-who-manipulate-you-and-are-usually-batshit-crazy-and-probably-usually-die-anyway-even-though-you-wish-you-could-have-killed-them-10mins-into-the-game
Only recently started watching Burn Notice... and straight away thought 'this is just like GTA!'
  • 1 month later...
  • 1 month later...
they said they need more time.
Dear all,
Today, we have an official release date to share with you: Grand Theft Auto V will arrive in stores on September 17, 2013.
We know this is about four months later than originally planned and we know that this short delay will come as a disappointment to many of you, but, trust us, it will be worth the extra time. GTAV is a massively ambitious and complex game and it simply needs a little more polish to be of the standard we and, more importantly, you require.
To all Grand Theft Auto fans, please accept our apologies for the delay, and our promise that the entire team here is working very hard to make the game all it can be. We are doing all we can to help ensure it will meet if not exceed your expectations come September – we thank you for your support and patience.
Yours,
The GTA Team
http://www.rockstargames.com/newswire/article/48591/grand-theft-auto-v-is-coming-9172013.html
meh i can wait.
:banana:
tell that to GT5
hahaha ^this
i'd rather them take a few more months to have a well made game, than release a broken game early/on time
hopefully the R18+ classification rating is all sorted and running by then
Edited by alex182
hahaha ^this
R18 is here. Itl all be g.
In saying that about GT5 though.... It was still not even half as good as forza 4 rofl. They focused on graphics rather than hardcore gameplay. GTA is a massive game though so it takes a long time to polish it. GTA IV was secretly just an engine tester haha GTA 5 will be amazing. However im a bit sketchy of the whole you play multiple characters. I miss having 1 character that you can eat heaps and get fat or go to the gym and bulk up haha
I know they arent into PC ports, but maybe theyre planning on doing one same time as release?
OR (and most likely)
theyre working with new Dev tools
Thats exactly what I was thinking, however if they say they are still polishing the console version then I wouldn't count on it.
It sucks for us PC players who usually have to wait a year after console release..
From a financial standpoint it would make sense for Rockstar to dellay the release for PC due to massive piracy of the game once its out on PC
What I am confident about this time is that they would have Ironed out a lot of porting issues and ineficiencies for the PC release.
LOL yeah right. the ports are getting worse with each release... San Andreas was bad, GTA4 was an abomination. same engine, so it might be a bit better, but still run like balls i reckon
If you compare performance with the first release and the latest patch there have been massive improvements. GTA5 will basically just GTA4 with new content so im confident this port will run the same or better than the last.
If it runs worse on console than GTA4 - which has a terribly bad fluctuating framerate then I would be concerned.
I agree the PC releases apear to run slower on PCs, but remember you are most likely doubling the resoloution from what consoles nativly run - PS3 and 360 only run GTA4 at 1280x720 and the earlier releases at standard TV res.
Fingers crossed it's not a disaster, eitherway I will be buying it and potentially optimize certain features myself as I have done with GTA4
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
