Seeing that all te intake piping needs to be changed, have you had a quote for that Gav?
No not yet - there are a few ways to skin the cat on this one. Given that the new GTX terbs have a 3" inlet (much larger than the 2" GT versions), I am thinking of new 3" piping from the pods to the compressor inlet.
where are you guys getting rear housings for dash 5s? I've been looking for some forever. new, used, whatever...
Perth Garrett dealer tells me Garrett have 13 in stock (I assume he means Garrett Australia?). Anyway, part number is 430609-230 and retail inc GST is just shy of $400 per unit.
such as? hoses collapsing? just curious, as I'm also running 90 deg silicon bends off my compressor inlets.
They have too much flex so it's so much easier for them to pop off. I've also had then weaken due to heat and split :(
+1
They can also catch fire... Or at least heat to the point they harden and crack.
I had 3 90 degree bends do that, usually around 2,000kms they would last (this was on the 31 years ago).
Gotta have a steel 90degree bends if you can when close to manifolds/heat.
Surely Hypergear could profile the new front wheels and then machine the standard -5/2530 front cover for a direct gtr bolt on..
...and sell it for the same price without turbine housings
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
