I'd be welding a short extension to the comp cover to get the joiner away from the dp, easily done given your using ally for the piping and will cost next to nothing as part of the bigger piping job.
Ceramic coat the manifolds, rear housing and dumps gav, it's worth it!
With my T04Z you could hold your hand right about the exhaust housing after thrashing, if you did that without the coating you would start smelling pork cooking :whistling:
They must have lifted there game, they coated a manifold for me years ago and the coating started flaking after a few dyno runs.
Really? That sucks, I got my GTR stuff double black coated and didn't have any issues and that nigga got hot haha :thumbsup:
Agreed. I melted 3 silicon hoses over 12 months in my GTS-R manifold/GT30 and there was more distance that in the pics.
Really needed to weld an elbow/extension just to clear a bit.
Yeah I would weld some ally pipe to the turbo. Id cut the whole snout off and weld a bend straight on for better clearance.
I JUST made a twin cooler piping setup / 3 inch intakes for my 32 GTR and the rear was a nightmare. I struggled to fit a 2.5" bend off the front on the rear turbo and then the 2.5-3" cone, then another small 3" bend. The actuator arm gets really close too. Youre in for a treat :) if youre not paying someone.
I might post a pic of my rear intake pipe later.
  • 3 weeks later...
The delay is my fault. Turbs all bolted up, but I'm waiting to get the car to a specific fabricator who will do the quality of work on the pipework that I want.
Note the shortened PS pump and the fact that I retained the HKS actuators as the bew ones fouled the oil lines.
Hopefully not too long a wait now.
  • 3 weeks later...
OK - all bolted back up now and tuned.
First things first - the new induction and compressor pipework.
Very happy with the work and is much lighter than the cast HKS pipework I had before. I also replaced the Blitz "flywire" units with some K&S filters that I'm sure do a better job of filtering.
Now - onto the dyno. Started off with the BP98 tune:
There was a fair bit of setting up initially as I changed the Apexi MAP sensors out to Greddy units (3 bar absolute) and ID2000 injectors. Once the preliminaries were out of the way it was clear that these turbos are a different beast. As we approached the limit of the boost of the -5 units, these really started coming into their own. The difference between the 20 to 23 psi (final tune) was significant with a LOT more power being made. Higher boost just started inducing too much knocking. We did make around an additional 40 rwhp, however, topping out at 581.
Now - the E85 is where it really starts to get interesting. Unfortunately I don't have an overlay of before and after, but previously we managed 620 rwhp at around 23 psi.
The new GTX units on E85 allowed more boost and netted a respectable 670 rwhp (or as near dammit an even 500 rwhp).
Again what was evident is that these terbs REALLY like boost. I'm sure that these could flow north of 700 rwhp on a stroked RB30 with the right head work.
Wow Gav. Just wow. Fkn massive result.
So can I just check please the final result on E85, that's at 23psi?
Did you try higher than 23psi on E85?
Any graphs in rpm instead of kmh please?
You've got to be happy with that result-must be just mental under boost in any gear haha
And the biggest one......do you have shuffle back again now?
Edit; I think you mean 500rwkw in the second last paragraph :)
wow!
can i just confirm that these are effectively the new range of -5s?? or is it something completely different?
also, dont mean to disrespect at all... but doesnt the larger size of these turbs make their whole use mute? cant exactly look stock with that fabrication (which looks awesome by the way!!)
Same rear (housing and wheel) as normal -5's, 2530's, 2540's, GT RS's and -10's.
The comp housing has a 3 inch inlet instead of a 2 inch and a 'revised' front wheel.
It's such a shame they are not direct bolt on. :(
I wonder where the 'limit' of these little housings are?!?!
Imagine it with another 7 PSI!
You wont get much better without a bigger A/R turbine housing; getting a bigger compressor wheel is not the issue it is the small exhaust side that causes problems especially if you want 500kW... using twin low mount internal wastegate turbochargers is the wrong way to make that power.
Is it still ? :nyaanyaa:
Congratulations mate what a monster. 500hp by 120kph I'm only at 300 at 120kph. 2.8 goodness there.. Only way iv ever make 500 at those rpm was holding the wastegates shut and ran 32psi yours is making all that power at low boost great work.. Do you have any plans of running it at the strip?
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
