Not sure where you got it doesn't include an exhaust housing?
Because it talks about the exhaust housing it comes with on there...
You're right, I skimmed through it and saw the image.
  • 5 months later...
Has anyone seen or heard of someone shoehorning a GTX 2860 into a -9 or -7 housing?  I have heard that it is possible but just haven't seen it done yet.  I think from memory you still need to use a -5 rear housing?
-5 rear is identical so it's best to use that.
Front wise -5 is to big and you'd need to use -9 from memory. Back a few pages are the gtx 2860s that I did but I used some weird stock turbo covers
Have you seen any power / dyno results from them?  I remember that you had them built but sold them on, trying to weigh up whether the extra hp over -9's is worth the $$$$
I posted this car earlier. It has since gone to a crank trigger and a few other tweaks. New engine so this is how it is for the first few hundred kms before cranking it up again.
Did this at 30psi previously. Still same GTX2863's
  • Like 2
  • 6 months later...
On 26.02.2015 at 4:01 PM, Meathead said:
I guess you could use the OEM comp hsg so sleeving is not required, In my humble opinion this would be a compromise so I just used some old HKS2530 hsgs which are T04B style (aka 5s) with an AR of 0.6
The OEM hsg. A/R is 0.42 and although from what I have read the A/R on the comp. side does not affect things too much unlike the hot side A/R which has a major affect on spool.
Using the OEM comp hsg might make it boost slighty earlier possibly hotter also. Just what I have read.
Anyway I prefer the HKS 2530/2510 gt2860r-5 housings of 0.6 A/R.
I just turned up 2 x 6061 aluminium alloy sleeves 60.00mm OD 42mm ID x 48mm long. Bored out housing to 59.94mm . heated the housing up with heat gun (measuring it to make sure its bigger than 60.00mm) , cooled the sleeves down in freezer then dropped sleeves in the housings. Once cooled machine the profile to suit . Interference fit is permanent like welding but no distortion. I put 2 scotch keys in as well although that was overkill but thats me. The important thing is the 0.06mm interference!. Best not to press it in cold either as it may gall.
Hope this helps some people out wanting to use GTX2860r CHRAs' with Skyline housings.
Keeping my fingers crossed they will be better than my 5s in every way.
thx for idea ) tuning my hks GT2510 to garrett GTX2860
Can anyone help me? is this map correct? 264cams 2.6
Edited by frakzz
  • 1 month later...
So I sold my -5's to a mate. Going on a z32 tt.
Gtx2860's are back on and setup with no boost leaks this time.
New engine and run in nicely. Still a 2.8 but nitto and crank trigger setup.
On bp 98 and 22psi goes pretty well. On e85 better again. Will get dyno tuned soon and hopefully run some more boost. She's spiking if I try to turn up gain. More work needed there.
Some custom intake pipes might get made up to replace the stock rubber ones. Running a mines front pipe with 89mm outlet, 100 cell cat and 89mm full exhaust. Not setup to dyno queen, but just haul in general :)
You missed a few steps. it's normally people saying they don't work, the poster say I'm going to make it work, everyone saying ok good luck, the poster saying it didn't work, everyone else saying we told you so
  • Haha 1
37 minutes ago, The Mafia said:
not sure what drugs you guys are on, but GTX turbos will be much better than -5s.
keen to see the results.
Every result posted has shown otherwise?
Putting GTX compressor wheels into compressor housings they weren't designed to be in, along with turbines that dont have the flow to generate the revs needed for the extra boost required for a GTX wheel to "do its thing" will be much better will it?
Be happy to be proven wrong but history will repeat itself.
  • Haha 1
Post 137. One of many examples.
J.U.N.K!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
