Not sure where you got it doesn't include an exhaust housing?
Because it talks about the exhaust housing it comes with on there...
You're right, I skimmed through it and saw the image.
  • 5 months later...
Has anyone seen or heard of someone shoehorning a GTX 2860 into a -9 or -7 housing?  I have heard that it is possible but just haven't seen it done yet.  I think from memory you still need to use a -5 rear housing?
-5 rear is identical so it's best to use that.
Front wise -5 is to big and you'd need to use -9 from memory. Back a few pages are the gtx 2860s that I did but I used some weird stock turbo covers
Have you seen any power / dyno results from them?  I remember that you had them built but sold them on, trying to weigh up whether the extra hp over -9's is worth the $$$$
I posted this car earlier. It has since gone to a crank trigger and a few other tweaks. New engine so this is how it is for the first few hundred kms before cranking it up again.
Did this at 30psi previously. Still same GTX2863's
  • Like 2
  • 6 months later...
On 26.02.2015 at 4:01 PM, Meathead said:
I guess you could use the OEM comp hsg so sleeving is not required, In my humble opinion this would be a compromise so I just used some old HKS2530 hsgs which are T04B style (aka 5s) with an AR of 0.6
The OEM hsg. A/R is 0.42 and although from what I have read the A/R on the comp. side does not affect things too much unlike the hot side A/R which has a major affect on spool.
Using the OEM comp hsg might make it boost slighty earlier possibly hotter also. Just what I have read.
Anyway I prefer the HKS 2530/2510 gt2860r-5 housings of 0.6 A/R.
I just turned up 2 x 6061 aluminium alloy sleeves 60.00mm OD 42mm ID x 48mm long. Bored out housing to 59.94mm . heated the housing up with heat gun (measuring it to make sure its bigger than 60.00mm) , cooled the sleeves down in freezer then dropped sleeves in the housings. Once cooled machine the profile to suit . Interference fit is permanent like welding but no distortion. I put 2 scotch keys in as well although that was overkill but thats me. The important thing is the 0.06mm interference!. Best not to press it in cold either as it may gall.
Hope this helps some people out wanting to use GTX2860r CHRAs' with Skyline housings.
Keeping my fingers crossed they will be better than my 5s in every way.
thx for idea ) tuning my hks GT2510 to garrett GTX2860
Can anyone help me? is this map correct? 264cams 2.6
Edited by frakzz
  • 1 month later...
So I sold my -5's to a mate. Going on a z32 tt.
Gtx2860's are back on and setup with no boost leaks this time.
New engine and run in nicely. Still a 2.8 but nitto and crank trigger setup.
On bp 98 and 22psi goes pretty well. On e85 better again. Will get dyno tuned soon and hopefully run some more boost. She's spiking if I try to turn up gain. More work needed there.
Some custom intake pipes might get made up to replace the stock rubber ones. Running a mines front pipe with 89mm outlet, 100 cell cat and 89mm full exhaust. Not setup to dyno queen, but just haul in general :)
You missed a few steps. it's normally people saying they don't work, the poster say I'm going to make it work, everyone saying ok good luck, the poster saying it didn't work, everyone else saying we told you so
  • Haha 1
37 minutes ago, The Mafia said:
not sure what drugs you guys are on, but GTX turbos will be much better than -5s.
keen to see the results.
Every result posted has shown otherwise?
Putting GTX compressor wheels into compressor housings they weren't designed to be in, along with turbines that dont have the flow to generate the revs needed for the extra boost required for a GTX wheel to "do its thing" will be much better will it?
Be happy to be proven wrong but history will repeat itself.
  • Haha 1
Post 137. One of many examples.
J.U.N.K!
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
