Finally leaving this group... Unfortunately not the way i wanted too lol
My stock NEO is finally tired, but it has copped a beating as a dedicated track car for the past 2 years so it was self inflicted!
Engine ran over 300kw, just shy of 400kw at times since 2011 and was daily driven up until 2015ish... Since then its been thrashed on track for more events than i can remember! Engine still runs and does everything as it should, its just pushing oil on track so time for a new build!
Stock NEO's FTW :cool:
  • Like 1
Me too :(
I have a new motor, it is unfortunately built lol
I blew (well Phil did) cylinders 1/5/6. Smashed a bunch of ring lands, filled the sump with metal, destroyed the head, and destroyed a fairly new turbo. Same as Matt, plenty of abuse and anti-lag launches LOL
56 minutes ago, Dose Pipe Sutututu said:
Me too :(
Lol you animal!
I pulled mine out before total destruction as i am building the original :P
40 minutes ago, 34GeeTeeTee said:
Lol you animal!
hahah well that motor was totes fuuarked, the bores were cooked the head was fuuarked too.. had engine bits and pieces holding some of the valves opened.
Had to buy another motor!
#neoforlyfe
  • Like 1
On 02/12/2017 at 8:10 AM, Stick180 said:
That was my thoughts, and at about $1200 AUD landed, its worth a shot.  Not sure on timing, but knowing my tuner it wouldnt be anything crazy. Because of the EWG spring drama, its not building boost like it should, and its dropping 2-3 psi upto. So once i have that sorted i think driveability will be much improved. When it is on boost, its very punchy and the spool noise is pure jizz
I just noticed your post and I'm keen to see more of your setup and results so far as I was looking at the S252SX-E for my RB20 with VTC as well. Do you have any more pics of the mods done to the housing ? Did you change the spring in the gate to improve the spool ?
#neoforlyfe
I am staying NEO... Just far from stock :D
RB20 with VCT? Talk to me about it haha. You using an RB20 Neo from a 34 or retrofitting VCT?
Nope i just retrofitted intake camshaft and pulley from an S1 RB25 on my RB20 (coming from a R32). I drilled and taped the camshaft cap to install some kind of banjo fitting through the cam cover in the cap , a solenoid and then back to the head through the cam cover again. The solenoid is operated via the nistune ECU. It looks sketchy but it's working and not leaking so far.
I'll give some pics for you if you're interested.
15 hours ago, NEO25T said:
Are you able to let us know the condition of the motor once its pulled down.
Would be interesting to know if a set of rings and bearings would freshen it up.
I wont be pulling it down, but can ask the question to see what condition it was in... I am going to say well worn though :laugh:
  • Like 1
Finally joining after almost eight years in the making!
Result: 318rwkw @ ~20psi, United E85
Full specs and dyno sheet here: https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/?do=findComment&comment=7866850
  • Like 1
Overall condition was pretty good mate! Nothing sinister really! Just tired!
  • Like 1
  • 4 months later...
I've just joined the club!
mods: RB25DET NEO, Hypergear OP6 .86 Exhaust housing, Splitfire coilpacks, 044 Fuel Pump (460 Walbro ready to go in), 1000cc xSpurts, Nistune, Garage 7 IPC, 38mm Turbosmart ultragate External (Off stock manifold), 3" exhaust, FMIC, Aeroflow fuel lines
fuel: E85
power: 330RwKW on 20Psi
oil: ULX110 10w40
useage: Weekender
lifespan: Only had it for a few weeks but it was tuned almost a year ago
failure: Nil
comments: Definitely want a garret and aftermarket manifold to increase boost response and some Tomei camshafts but other than that this is way too much power for a street R32 haha
fuel: E85
oil: ULX110 10w40
useage: Weekender
failure: Nil
You could just swap the op6 housing for a 21u housing, will be all in full boost at around 3500rpm and only lose 15-20kw. Another option, upgrade the bearings in the turbo to ceramic ball bearing. Both of these options will be relatively cheap and make a reasonable improvement.
Otherwise a gtx3076 gen2 on a 6 boost will sound tits. Wouldn't bother with the cams, not required.
On 6/16/2018 at 3:19 PM, GTSBoy said:
Well, poncams are generally crap.  And they will NOT give you the response increase you're looking for.  Just the opposite, in fact.
Ah i thought tomei was well received with RB stuff, knew they were unpopular with toyota because they snapped a lot.
Also found out my turbo is actually an ATR43SS2 .82
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
