Why the change of ECU?
Never heard of a Emtron
how do they compare to the elite 2500?
I would say that the features they advertise actually work. Might even be able to track a Nissan cas unlike the haltech elite.
  • Like 1
Emtron is Scott from Insight motorsports own ECU. I would say it pisses on a haltech as you do not need to buy a box everytime you want your ecu to do something. I also believe it has alot more inputs and outputs etc also.
Basically i believe an emtron is knocking on the door of high end motec kinda stuff feature wise without motec pricing ?
Im sure someone can correct me if im wrong Lol!
  • Like 3
I like my passenger floor not to be filled up with "add on boxes". Lol.
Emtron was developed by Scott at Insight. For what it can do it's very reasonably priced... And no need for extra boxes! The Blackbox wouldn't do a couple things that I wanted it to do. Great piece of gear though.
Hmm your not wrong about those stupid add on boxes, they also drive the price up the of them you have.
Im in the market for a new ecu for my new build.
I might look into the Emtron
IMO if you're chasing anything decent power it's time for a trigger setup. Gets rid of a variable.
What at sort of $$ for the Emtron? Are they easy to tune or very specialised bit of kit? That's probably where the Haltech range are attractive, they're quite easy to tune (up to a point anyway).
Cant wait to see this thing bangin through the gears! ETA on completion?
  • Like 1
Emtron KV8 (there is a 12 and 16) was like $3,200 GST inclusive. $880 for a patch look so you don't hack up your OEM loom.
I would like to think not long but it also needs time for ECU install. That's tuner dependant. We all know how it is. Lol.
8 weeks perhaps? At a guess.
https://emtronaustralia.com.au/shop/category/product/?catid=1&prodid=1
emtron link...
I'd firstly work out exactly what features u need then make a decision on the right ecu for you. I previously had a vipec then moved to blackbox as it had the additional ports I required....nowa days, more tuning shops are playing blackbox which is favourable as well :)
I guess there is no point in spending more if it's not needed...
emtron link...
It's a cowboy industry, YEE HAA! Enjoy the ride as many of us have to date.
Hey Paulie, any idea what it cost to drop the subframe ??
Will your whale be street legal ??
When it's finished , why dont you ship it to Japan where you can drive it as fast as you want to. I'll look after it for ya :22_stuck_out_tongue_winking_eye:
Marcus!
if you have time, flick me a call when you're free and I'll give as much info as I can. I don't know specific costs yet but I'll get a bill at the end I'm sure.
By no means is this thing going to be a track pig only car. Drive it to work on Saturdays, go down the coast for lunch. That sort of stuff.
fizzing at the bung to get it going. So close now :)
On 26/08/2016 at 7:20 PM, Piggaz said:
Marcus!
Will try call in next few days as I'll be out bush again digging rocks.
  • Like 1
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
