16 minutes ago, sneakey pete said:
Don't think there'd be the space between the rad support andt he bonnet?
Tried to find a photo... failed. I'll find it... somewhere but it has been done. Not sure if they modified the snorkle but I don't remember it looking "not factory".
There's no over the radiator support intake on the 32's. Just a oval intake under the headlights that clips into the airbox. There's also a port between the in engine bay and the behind front bumper area on side behind the factory wiper washer bottle. How many intake options do you get on the 33's?
  • Like 1
I know that, but it looked like they used a 33 snorkle. Grab one and see if it fits, even if it doesn't, it can't be that hard to make work.
Must be getting excited seeing the finishing touches coming together:1311_thumbsup_tone2:
A shame you have to earn the $s before you can put this type of build together , just hope I live to see it done, thought of getting a 3rd job, lol
You must take some vids when you turn the key for the first time, it will be one mad Boat:530_checkered_flag:
1 hour ago, SimonR32 said:
Piggaz vs Bobby for longest build and never driven...
But I do joke, keen to see some results on this mate, well Bobby's as well because that will be the joke :)
The zombie apocalypse will come before this car is ready
  • Like 1
  • 1 month later...
Car is finally booked into Insight on the 19th of April for the ECU, fuel system and sensor wire in plus the tune. Thats the good news. The bad news is that V-cam aint gonna fit with my pistons and how my engine has been setup. I had a chat with the bloke who screwed it together and with my positive deck height (+22 thou higher than factory), decked head, larger valves and god knows what, the only way to do it is to have a set of pistons made up with a thicker crown.... I'm not doing that!
So, bring on the 19th! Hopefully it runs before end of financial year!
Update of engine bay. All thats left to do it swap the harmonic balancer over annndd thats it.
D91B0863-1182-4E4C-8370-94E66E31EF9B_zps
  • Like 10
3 minutes ago, acsplit said:
Good good, don't worry it won't need the Vcam.
Because single and not twins? ?
Vcam WILL come. Just not yet. I want it on the road, not another rip apart!!!!
5 minutes ago, fatz said:
No need to change computers then if no v cam
More to It then that Pete.  That was more of a personal issue and a "f**k you" then anything.
Its done, it's dusted, whatever.
Just want it running. I have a date, that's it. Get it on the road!!!
1 minute ago, Deano 1 said:
Soooo no Emtron?
Emtron KV8 is a goer. Just no v cam. Box that guy up and save it for the inevitable rebuild... we all know how RB's are ?.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
