Probably not far over, if at all or ever but it made sense to me to future proof it while it was being done.
I wanted something reliable so my concept was build it for like 500+ or something and I could maybe expect it to last a bit at 80 or so % of its capabilities as I wanna be able to rack up some laps.
Made sense in my head :)
Wiring is in progress and will be finished by Tuesday next week, going to need some heavy duty straps to hold this thing back from jumping off the dyno seriously.
No PRP brace on this build, we have followed the laws of physics not marketing hype.
Don't fancy redrilling/replaneing that thing to suit anyway. No CDM parts on my car, only JDM & USADM
I think it will be hard for the car NOT to make 300kw , gate springs are 14psi and I expect this is the figure I'll be getting.
I mean, obviously, the head is akin to a Mario Rossi daytona 305ci head & this is what happens.....make big power easily.
Moreover, I think the thing I'm most excited about is the sound....a big valve head with a big bore no nonsense exhaust. One rear muffler only, can't disturb the exhaust gas when I'm on the limit...but I can disturb the neighbours within a 3 block radius honestly. It's going to sound like a peripheral port 3 rotor, I've done the maths.
Cheers,
Benny "The Don".
  • Haha 1
  Nice, I imagine a reasonable middle of the road strap on (for general home use  would have a strong enough strap to hold it to the dyno, but good to hear you are also over thinking that.
Mario rosi daytona head is also NASA spec? Just trying to keep up.
Can you share the maths for calculating what the exhaust will sound like?
Basically yes....and I've done it all without sponsors.
As for the sound...its all about the wastegates merge, 2 into 1 then into the main pipe, will make it sound like a 3 rotor.
Will be serious velocity, I told the tuner to make sure I'm spitting 6 foot flames like the Brill Steel S15.
  • Like 1
I think it will be hard for the car to make 300kw because my gearbox can not hold stock turbo power , gate springs are 14psi and I expect this is the final boost pressure needed to turn my gearbox into marbles.
Moreover, I think the thing I'm most excited about is the sound....a big valve head with a big bore no nonsense exhaust. One rear muffler only, can't disturb the exhaust gas when I'm on the limit...but I can disturb the neighbours within a 3 block radius honestly. It's going to sound like a peripheral port John Deere, I've done the maths.
Cheers,
Benny "The Dong".
FYP brah ?
  • Haha 2
Haha well to be fair, I'm not sure PRP were trying to market towards the 240kw SR's with those braces...
Is this your car?
https://www.gumtree.com.au/s-ad/wahroonga/cars-vans-utes/2002-nissan-s15-200sx/1251512935
I guess I was wrong with the Samsonas and the power, but 506kW was close enough.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
