simon you still running standard valve springs?
suprised your not getting valve float on that boost and with bigger cams
As far as I'm aware they are standard, the Japs put the Grex cams in back in the day and they are only 9.1mm so only babies in terms of lift. Have never thought to check valve springs but I highly doubt it, they didn't even put aftermarket head studs in, just wacked the cams and head gasket in.
I was more worried about head float after the standard head bolts stretched :)
Me like-y, very much. R33 bottom end or R32?
Same motor that came with the car in 1991 (R32) but it's a very low km example... Done 46,000kms
Edited by SimonR32
  • 4 weeks later...
Pretty much same setup as the 8.97sec pass as before a few changes likenew fuel system and Upgraded head components have also switched to Methanol Fuel. Also dropped 140KG out of car now weighs 1280KG. We are currently running estimate 850-900 KW at the wheels.
Best ET is a 8.39 Seconds at 164MPH with a slow 1.3sec 60FT on Mickey Thompson Street Radials, currently makes us the Worlds Fastest street Radial Tyre RB Powered GTR, and also the Worlds Fastest H-Pattern Radial Tyre GTR. Only cars left to beat is the AMS R35 GTR which done a 8.28sec on Radials and 7.98Sec on slicks. Both those time are achievable with our current setup. The car is still not setup a 100% with its new systems a bit more fine tuning.
-HKS T62R Turbo
-Jun 2.7lt Stroker kit with Custom 86mm CP Pistons. Godzilla Spec Engine.
-Godzilla Motorsport Race Head
-Custom Godzilla Camshafts (Top-secret Classified Info)
-Full Supertech Valvetrain
-Hypertune Plenum with 4" Throttle Body
-ARE 150mm Intercooler
-Trust Exhaust Manifold with 50mm Wastegate
-Moran 5000cc Injectors
-Vipec V88
-M & W CDI Ignition with Weapon X CDI Coils
- Aeromotive Mechanical Fuel Pump
-Peterson 4 stage Dry Sump Setup
-4 Inch Custom Titanium Side Pipe
-NPC Twin Plate Clutch
-PPG 5 Speed Dogbox with Ignition Cut.
+ a lot more
http://www.youtube.com/watch?v=KNLs_gONSQ8#t=1
  • Like 2
-HKS T62R Turbo
-Vipec V88
+ a lot more
if you dont mind, what are you using to cut ignition on changes?
if gearknob, what brand, or do you have name of supplier?
cam pm if you want.
thanks, luke.
  • 2 years later...
Joined the 500Kw+ club today with the V3 prototype of my engine. This was the power goal that I had hoped for, as it is designed to be a torque monster with the maximum possible low end performance.
The tune is on E85 (75% content after the 98 octane tune), and was done in Cairns in 33 degree heat at 82% humidity.
Open Deck Engines 3.4lt (3360cc) Block (Rb26 24U based block)
Tomei Spec 2 head, Step 2 cams.
Precision 6466CEA 1.0
Full Race manifold with twin tial gates.
4" turbo back, 90mm Trust TI-R titanium exhaust
Greddy intake plenum
Nismo Intercooler
NPC twin plate
Haltech with IO expander, doing fuel pump and auxillary cooling system control
PWR 55mm twin pass radiator and custom oil-water heat exchanger, plus auxillary rear mount radiator and remote coolant pump.
Ignition project plazma coils
Completely enclosed crankcase breather system, designed to pull the engine into a vacuum under boost.
  • Like 1
Vented back to between the air filter and turbo and running a exhaust vacuum source with check valve?
No check valve, and no exhaust vacuum interaction. Pulls vacuum from the sump and head via a baffle system, to a ventrui on the intake between the turbo and filter. Any oil that enters the system returns to sump like a nismo setup, but at an elevated temperature to boil out any water vapor.
  • Like 1
Have you measured how much Vacuum your pulling in the sump, or are you just managing to pull blowby?
We were preparing to hand make a venturi between the turbo and filter, a few people suggested i look into the exhaust scavenging setups but my thoughts were that it may not work as well on a turbo setup as it does for the V8 guys.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
