Got a bit of a start on the dump. Cut the taper to fit the v-band, ground it perfectly flat (one of the (multitude) of keys to a half decent tig weld I slowly discovered doing the rest of the exhaust...) then tacked them together. Measured up the first bend off the taper and cut the end off the 90 degree bend. Because of the front mount manifold it means the turbo is on an angle so you need to go down and away from the engine at the same time. Makes it a bit trickier...
I'll be cutting more off the end part way through the 90 but tacked it on and I'll work out where to cut it while it's in place.
20191011_212053.thumb.jpg.7c3bdb03fd2a031171b94c9ae73fbd65.jpg20191011_212038.thumb.jpg.65b2f472393c1b03d7215d0623910a30.jpg20191011_212249.thumb.jpg.0d92efaf4ea047f3ab2ed1514ce708ce.jpg
20191011_212301.thumb.jpg.b189a0e0a8818d53cd14e5e5194248ea.jpg20191011_220833.thumb.jpg.5e9b018e95abced6598338f20e1c4355.jpg20191011_230857.thumb.jpg.af1a1ea935465bdc2a62b0b8434686a6.jpg20191011_231020.thumb.jpg.8233c6a2584a2bc94f8f6a2c381dd20b.jpg20191011_231010.thumb.jpg.e2af02083b6eb1dd6c05c0046180f5fe.jpg
  • Like 2
Ha ha!! You’re persistent!
I currently have one point left on my licence so I’ll be looking for ways to be less obvious to inspector Po Po. I don’t think a bonnet exit exhaust and screamer will help me achieve my goals ??
  • Shoota_77 changed the title to Shoota's R33 GT-R RB30/26
Got a bit more done of the dump. Pretty much out the bottom now.
Has anyone come up with a solution for the a/c evapirator drain pipe? Ive gone closer to the firewall than standard. Might just chop most of it off and leave a little dick poking out.
Did my first full (not just tacking) weld on the dump pipe. Did a terrible job ?.  The rest of the exhaust I didn't use filler. With the dump I did so felt a bit uncomfortable. I get so bloody nervous and jumpy when im welding.  I need to chill out and slow the f down!! Once it's ceramic coated it won't be so obvious how nasty it is.
Slow going but good to be making some decent progress!
20191013_150351.thumb.jpg.628035b2604d3bab028ba3d55c04069f.jpg20191012_170836.thumb.jpg.aeddea2fb83d091e364dd472fced7b4a.jpg20191012_170842.thumb.jpg.664abed34b85ba18062c5e8a205c9589.jpg20191012_170831.thumb.jpg.4c2e6dc1738e479a015d7f3db4ab0cb5.jpg20191012_223013.thumb.jpg.ff88cdba70ee438130d704f424c10e68.jpg20191012_223019.thumb.jpg.7b57c5a8a785531d30494275ea9777df.jpg20191012_230423.thumb.jpg.71a88e411375f38a64fd47b65a18d08a.jpg20191012_230449.thumb.jpg.7c082093d07ee9a59d4286127bbee1de.jpg20191013_150351.thumb.jpg.628035b2604d3bab028ba3d55c04069f.jpg20191013_150503.thumb.jpg.c6892a1f1426c1c1822231f4deea3bab.jpg
The only restriction in mine is the dags from my cocky shit welds! ?
I'm a bit scared with how loud it will be with just a rear muffler. May have to put a resonator in it at some point.
Thanks mate. I probably put a bit too much pressure on myself for a bloke who learnt to TIG off YouTube!
The sense of satisfaction at the end of this bloody long winded exercise from having done everything myself on this car will quickly overcome my self disappointment over a few shoddy welds!
Just have to keep pushing while the motivation bus is in town!
I’m up in Sydney for 3 days at the moment so missing a few nights in the shed after work because of that.  Hopefully got a few full days at the end of the week to finish off the exhaust.
A few more bits and pieces done.
I seem to be 2 steps forward one step back. I keep adding and changing stuff as I go...
The dump pipe was getting too long to feed down through the engine bay so I've added an extra v band in to make removal easier.
  • Like 2
Got a few more sections of the exhaust done today.  The dump is almost connected to the cat which is he original part of the exhaust I made when it was still going to be twins.
Went and got a few sections of 3” stainless bead rolled to be used for the compressor side to intercooler and then on to the intake.
Had the compressor housing hose section machined off to allow fitment of a v band rather than a hose. Need to order in the 90 degree bend though as it’s some sort of weird v band size...
Got a start on the wastegate merge into the exhaust. Wow, that was a shit of a job cutting the pipe to fit the exhaust nicely. I just couldn’t get it perfect. With TIG you don’t get too many chances with crappy joins. Decided to just go with it and try to panel beat it into submission! God I wish I had a pipe notcher after that.....  Would have made it so much easier than all the cutting and grinding I did on it.  Took me  Hoooooouuuuurrrrrsssss!!  Started tigging it up using heaps of filler wire to bridge the shonky gaps!
Still a fair bit to do. Waiting on another flex joint (baffle style) as I wasn’t happy with the one I already had. It was way too big. It’s supposed to be 4” but the 4” tube was dick in a bucket. Way too big to be able to TIG. Even MIG would struggle to bridge the gap it was that far off.
  • Like 1
Pretty much finished off the wastegate merge. Man what a mission I made that into.... I reckon i put 5 or 6 hours into that section alone ?
Lucky I'm enjoying it! Such a sense of achievement each time I finish each section.
  • Like 1
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
