Nothing much to show in photos...
Oil and coolant feeds/drains all done.
I'm currently assembling everything to prepare to hit the key.  I keep finding things I need to modify the more parts I put back on!
Some stuff I will go back and fix later on, getting it on the road is the priority for now.
I kept (for now) the factory coolant pipes (modified obviously)  for the turbo water feed. I raised it up to clear the turbo and decided to add a bleed screw into the banjo bolt as it is now the highest point of the engine. Worked well for bleeding while filling the cooling system.
I'm just finishing off the oil filter rellocation, running -3 AN fittings and braided hose to the MAC valve, install and wire in the turbo speed sensor, tidy up the wiring then it will be pretty much time to hit the key. I've primed the system to get oil into the turbo before starting it so it's not spinning up with no oil pressure.
Will hopefully get the water meth kit installed by next week but not a priority at this point. The water meth with be more beneficial when on pump as opposed to E85 but will be interesting to see if there are gains/benefits running it while on the corn juice.
No doubt there will be other little bits and pieces to do but will hopefully kick it in the guts tomorrow night!
Photos show how dusty the poor thing is from sitting in the shed even under a cover. Its had 2 washes in about 6 years I think....
It's been a grind let me tell you!  Most nights during the week plus every Saturday afternoon and full day Sunday for the past 9 or 10 weeks.  It's probably the longest stint I've put into it in one go.  The light at the end of the tunnel is close enough this time to keep pushing!
  • Like 1
Ok, so the engine starts and it runs.  It doesn't idle and it doesn't run well but it runs!  It has a bit of a miss which I think is coil packs which got cooked when a setting was wrong in the Haltech early days.  New ones hopefully here today or tomorrow.
I've got two (major plus 50 smaller) issues I'm hoping for some input into.
1.  How noisy are EFR turbos at just above idle?  Mine (with no air filter on) sounds like it's pushing 50 PSI at just over idle!  Goddam it's bloody loud!  An air filter will quieten it down but damn it's loud...  I didn't take a vid as it was getting really late when I came inside last night.  I can grab one tonight.
2.  Clutch issues.  I've got a shit pedal for the clutch and is not releasing enough to be able to select gears.  I've adjusted the push rod to maximum length and I've bled the system but it may need a re-bleed.  I'm praying it's just fluid related as if it's not it could be box out job....  My other concern is I've done a clutch booster delete so have a different master cylinder in it.  I'm wondering if it's not pushing enough fluid...  Looking from underneath the clutch fork is already sitting around halfway along the opening in the side of the box so I'm wondering if the release bearing maybe didn't engage properly in the clutch fingers.  Is that a thing with pull type clutches?  Or would it be fully disengaged, not partially?  I'll have more of a play with that tonight.
I'm happy it's running but it's so frightening when little issues crop up!  I'm shitting myself that it's not going to be right for next week!
Hi I love the build. I’m looking at going 2630 in the near future great info.
regarding your clutch, if the release bearing wasn’t locked in clutch it wouldn’t activate at all. I just went threw this with my GTR R33. I put engine and gearbox in twice both times the release bearing didn’t lock in ?. So I went f**k this converted to push type, also I done the booster Delete and it improved my clutch feel heaps ?
Edited by Everit26
Forgot info
  • Thanks 1
Cheers @Everit26.
Ok after further investigation it appears as though I might be an idiot....
Turbo noise was because I hadn't put in the speed sensor yet so that was the sound of a compressor wheel passing a small hole at a few thousand revs ??.  That was stressing me out so I'm glad it was nothing!
Clutch took a bit more effort. Ended up pulling the slave off the box, poking it back up through the engine bay and bled it by pumping the slave back through the master. Got all of the air out, poked it back down below and all good now! Still not a fantastic pedal but it fully releases now so all good.
I've still got a miss from cylinder 6 that's proving a bit tricky....  I've swapped over coil packs,  replaced spark plug, swapped injectors, checked injector pulse, checked spark with the plug out and still no joy. Injection is there. Spark is there so I'm a bit perplexed....
Further investigation required tonight.
Crappy vid attached.
  • Like 1
Ok, sort of an update.  The car is mostly back together but I've decided to postpone the tune from this Thursday to in a couple of weeks time.  At about 10:30 last night being about the 40th consecutive night (give or take a few nights where I had stuff on or was away for work) I've worked on the car I decided that two days just wasn't going to give me the time to get it all done to a level that I was happy with.  There are still a few things that I want finished to a higher level than I would have if I was handing it over to the tuners on Thursday.
It was a gut wrenching decision to be honest but comparable to the effort required to get the car to the tuner to find something went wrong it was the preferred option!  I live 3 hours each way from the tuner and they need it for 2 or 3 days (to do cold starts for 98 and E85) so it means dropping it there, coming home then back a day or two later to pick it up meaning a total of 12 hours driving over 2 days.  I want those 12 hours of driving to be worth it!
Now I can take my time a bit to finish off the last few bits and pieces and make sure everything is ready to go rather than such a rush where I'm worried something will go wrong.  I'm glad I had the deadline to work towards as it made me work my arse off to get to this point meaning it's now a stroll to the line rather than a sprint!  If I hadn't had a date to work towards I'd still be a long way off, that's how my brain works...
Pretty much all I have left is fitting the water/meth kit (which I would not have got done in time for the tune), wiring in the turbo speed sensor, replace the crappy Mishimoto thermo fans that feel like they move about none air with some decent Davies Craig fans, refit headlights/front bumper/bonnet/etc, fully wrap all of the engine bay wiring looms (I've got wires everywhere at the moment...), and then whatever other else I trip over along the way!  I also want to fit an oil cooler and properly mount my remote oil filter somewhere accessible but out of the way.  I've got the 2 channel Haltech O2 sensor kit but I'll change that over for the single channel now that I'm not running twins anymore.  I'm sure it will still be fine just to run one of the 2 sensors but I'd rather the right kit.
I think I need to fit another muffler too as damn it's loud!  Sounds amazing but will be too loud for the street.  Skylines are cop magnet as it is let alone sounding like a freight train!  I'm on licence probation for 12 months so need zero reasons to be pulled over at the moment.....
Still heaps to do but now with a bit more time to do it!
  • Like 2
Ok this one may make a few people scratch their head and ask "Why?" particularly when they see where i did what, but well I did it because I could.....
So what I did was remove the power steering pump and replace it with an electric power steering setup. Astra of course!
I know most people put them in the boot and use weight balance as a justification for the exercise but I'm not most people!  I looked at a lot of locations but decided to leave it at the front because i can retain the existing return line cooler and just replace the pressure line with -6 hose. I'm going to try fitting a pressure regulator in the return line (not set too high) and a one way valve in the pressure side to see if holds a bit of pressure across the pump. I've heard people complain about a slight delay in building pressure but that might just be because of long hose runs from the back of the car.
It certainly makes a lot of room in the front of the engine!  One less belt to fly off or need to replace too...
The random photo is a guy I handed over a $200K Audi RS4 Avant (wagon) to during the week. He won it in the Audi Foundation raffle. Not a bad return on a $50 ticket! The winner cant drive the car without modification so the car is most likely for sale for around the $135K mark (pre onroads) if anyone is interested... Amazing V6 twin turbo 331kw beast!
  • Like 1
Exciting (sort of....) when you find out tour 'replica Nismo front bumper and is actually a genuine Nismo 400R bumper!
I better keep it now, I was going to turf it and track down a genuine plastic bar...  It needs a few small repairs and a repaint but that will have to wait till my  credit card has some fresh air between what's currently on it and the credit limit...
Assuming that is you shaking the chap's hand, I understand your choice of previous profile pic
Longest gap between posts for a while....  Been very busy with work the last week and a bit. Had to get an accreditation from Audi so had a massive project to put together. Well it felt massive anyway (that's what she said???) seeing it's been so long since I last studied anything other than hot birds down the street...
So, I had to pull all of the wiring out from under the dash (prick of a job when you have ABS) as I had to add some extra wires (turbo speed sensor, water meth wiring, new single channel wideband 02 controller, Haltech rotary dial plus some other stuff).  I realized that when doing wiring I procrastinate a lot as it's such a fiddly prick of a job!  I don't mind it, I just CBF doing it!
I worked out all my wiring loom branch locations on the engine then stripped it all out and wrapped it with wiring loom tape (no, not electrical tape, loom tape is wider and a nicer matte finish).
During the process I discovered what my engine miss was. On the Haltech loom the injector wires are blue with a trace. Cylinder 5 and 6 are a yellow and an orange trace.  The yellow trace is a lot wider but in the average light of my shed they look the same colour. You can see where I'm going here.....  Yep, back to front!  It was running amazingly well considering 2 cylinders were running off fuel that was sitting in the manifold at the wrong time!  It wasn't a miss, more of a stumble/hesistation. I started it up after reassembly and all seems good!  Thank God as it was still worrying me.
Still got to replaced my crappy Mishimoto fans with some Davies Craig fans, mount the water meth tank, then just do as much as i can to get it ready to go back on the road (bumpers, bonnet, headlights, etc).  Tune is booked for Thursday so at this point I think we're looking pretty good with a few nights left to go.
The good wife gave me some money for my birthday to put towards some personalised number plates so got GTR21.  Bit wanky but I like them!  They're a bit taller than I'd prefer but they'll do.
  • Like 2
Electric power steering is all wired up and plumbed in. On the hoist it seems to be working fine. No leaks so that's a bonus!
I'll hopefully go for a slow tootle up the road tonight to see what falls off!  I'm assuming I'll lose at least one major component! ?
A bit of reassembly tonight,  mount the water meth tank, plumb it in and we're as close as were going to get to done before the tune as was possible.
  • Like 3
Ok so f**k is the most appropriate word for my night last night.
It's my own fault for leaving it to the last minute (well sort of my fault, mainly for putting too short a timeline on things).
So after getting most of what needed doing done I lowered the car down off the hoist for the first time in many months, started it up, eased out the clutch and goddam what a noise started coming from the transmission!! It sounds like it's trying to grab 2 gears at once so making so horrid grinding noises. The transmission is one of the very few unknowns to me in this whole build. It's pretty much the only thing I haven't done myself (unless it's the transfer case which I did modify...).  I bought it off someone years ago and it had allegedly just been rebuilt. Maybe it was but it wasn't checked afterwards. It seems to be fully engaging with the shifter but something is not right in there. I'll try and narrow it down by first dropping front shaft to make sure not front axles, then maybe see if I can get the transfer off while it's still in the car to see if I can eliminate that. If the noises are still there then definitely gearbox.
Ahhh the joys of doing your own work ??????.
Very frustrating and demoralizing to be honest but we soldier on. Will now have to put off the tune till next year unfortunately. Will mean I can finish off everything though which will be good.
I need a day or two off it to clear my head first then I'm back into it.
  • Like 1
  • Sad 2
That's shit luck but these things happen. Just about all of us have experienced some sort of setback in the eleventh hour with our Skylines. You're not too far from enjoying the fruit of your labour. At least you can finish off at your own pace now and make sure it's right ?
Thanks for the kind words. I'm pretty resilient normally but I've just got so much built up emotion in this car plus the frustration of failing its been a real kick in the nuts!
All good, onwards and upwards!
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
