Hey mate good to meet you today ! Here's pics of that steering wheel I was talking about if I owned a 32 I would also own that wheel !
Hey mate,
was good to meet you and have a chat. Awesome 34R. I may get in touch with them and see how much they are. The 34R steering wheel they do is awesome. Wonder if it'll fit a 32?
Yeah, it is addictive. In fact most GTR parts are addictive IMO.
I have the same as well in my car mate ;)
Where can I get that carbon wrap for the middle compartment, gear boot and handbrake boot? I want badly!
Also what gear knob is that? Looks dope.
rhdjapan.com have all 3 carbon parts in stock. They're made by a company called "Superior Auto Creative", not cheap but they're worth it.
Ants has a Nismo GT Urethane gear knob
LOL. Edited my post after seeing that you had replied.
Champion.
Thank you very much. Props on the work you have done to your 32 thus far. Looks dope, many of us are envious I'm sure! :)
Mind estimating the amount you've dumped into it thus far? :P
Edited by Cevzy
Champion.
Thanks mate. Have decided to concentrate on the cosmetics over the next few months as the mechanical package inc brakes, handling etc is pretty good now, just needs some minor tweaking.
As far as cost goes : I had a spreadsheet somewhere but I've stopped looking at it a while ago. They were a car that cost around the 100k mark when new so I dare say the average GTR build on here would hover around that number more or less too? Folks on here - Feel to correct me but that's been my observation so far :)
  • 5 weeks later...
  • 4 weeks later...
Was booked in for Winton mid October but had to cancel as we're moving house. Everything in life is being upsized currently, as the Mrs and I are expecting our first "mini-me" in a few months. Not much time for the car lately unfortunately.
Managed to get it out of storage and drive it to work and back to give it a run for a couple of days. Noticed the interior lights and rear lights are no longer working. Great. After a quick search it looks like there is no fuse and it runs off the headlight switch. So....
New headlight switch. $187! Pretty steep especially when you open one up and see how basic the design is. Thanks Nissan.
Wasn't too hard to get to the switch. Steering wheel can stay in place and just the cluster surround and lower panel need to come off. While I was in there, installing the new headlight switch, I found the plug now looks like this. Great.
Looks like the worn out headlight switch results in a short which then screws the plug up good. Not replacing the plug only lasted me a another drive until the lights went out again.
Thought I had to go scrounge around a whole bunch of N14 Pulars at the wreckers for a replacement plug. Luckily I found a dude wrecking a 32 and bought a black rear bar and nice un-burnt plug. Even came to my work to drop it all off. Nice bloke.
All working again. now. Oh did manage to make it to the SAU VIC cruise to Daylesford. She ran well. Met lots of great ppl on the day too. Needs air-con gas stat. Might get a mate who is a mechanic to gas her up.
10712410_951976264828750_660088222878022
On the plus side our new home has a secure double garage so the car finally live with us. Looks like it'll be a whole lot more convenient to get work done on the car after that ;)
Beaut.
Them switches grrrr
I think I paid about the same after going through 3 second hand ones.
Now I hear there is a guy on here that will fix them :(
Beaut.
Them switches grrrr
Amazing how many little things need to get done to these cars now that they're getting on. Take for example the fact that I had a squeeky/grinding clutch pedal. No amount of lubricant could fix it. It ended up needing 6 replacement bushes from Nissan. Total cost $65 + labour to fit.
I would really hate to see how shagged one of those GTR's selling for 12-15k would be.
  • Like 1
Shiv, you should come down to the show and shine @ Skyline Nationals cup weekend if you can make it.
I'd bet you will be a contender for best R32 :)
Plus we need to have some beers.
That it does. So when's the Exedy heavy duty going in :P
That is a nice clutch but I don't think it'd survive my fondness of hard launches.
Jarrod!
Definitely considering going to have a bit of a look. The car's good but I don't think it's show material quite yet :)
Beers are defiantly over due mate, we should tee something up.
Jarrod!
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
