I spoke to the Russian today and he said that even thou it is a costly exercise he is working on a cheaper solution. He said I needed advanced soldering skills for the current option and its exspensive to buy equipment to do it.
I must say the English head unit is working great
GPS maps work great, good voice nav, all menus are English, bluetooth is good, pretty much full functionality except for the weather and traffic info and TV but I've been told I can fit a DTV tuner. USB cable in the glove connects to iPods etc to be displayed on the screen, very quick, no lag
Stickers for buttons are a bit tacky but from a distance looks almost stock
Would highly recommend if you have money to blow
What about the newer model?
Is it the same process?
Aren't 2010+ models easier?
From my conversation with him, it looks like he is charging the same amount but I think there is much less work. Something about him needing the nav deck n changing something in there. I'm not too sure.
Good to hear! I was thinking about getting a V36 after I wrote off my R33, but the non-English headunit has put me off a little. Sounds like it's less of a mind f**k now :)
What are the contact/business details?
Wonder if he'd want to fly to Adelaide for a weekend :P
  • Like 1
Hi
How can i get in touch with this guy? I have a 370GT 2010 model and my friend has the 2010 model. I would be very interested to convert our cars.
Any help would be appreciated.
You cant, He all ready has someone in Sydney doing the conversions for him. He was just trying to come up with a better solution that may be cheaper.
I was told its exspensive to set up the gear to do it. Hence why only Sydney do it. They have a bigger market.
ROAD TRIP!!!!! :)
Really? I must have a freak unit then because I can play all regions and it continues to operate even while driving. I have checked the wiring while I was upgrading my sound system and there weren't any signs of any modification - at least, not externally.
I still haven't pulled my finger out and tried my Mirrorlink device via the AV inputs to see if I can mirror my phone's screen on the in-vehicle LCD but after experimenting with it on my TV, it looks passable and I think I might get away with it after all in the car. I'll give it a crack tomorrow and see if it works or not.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
