I'd be cautious about wheel nuts for a race car, I've seen lots of nasty ends due to simple problems. In particular I'd never again run alloy ones, steel only for me - I ran alloy for about 2 meets before deciding I didn't like the look of the wear as they came on and off, and got hot.
Is the problem that you can't fit the wheel nut into the hole (ie nut too large diameter), or that you can't get the nut onto the thread adequately (studs too short).
I recently had trouble getting standard (21mm socket) nuts onto the Leaf's new wheels so I bought these and they have enough space: http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=181334793255. Also you can get thin wall sockets for putting wheel nuts on eg http://www.ebay.com.au/itm/Kincrome-Wheel-Nut-Socket-19mm-Yellow-K2183-/271418431242?pt=AU_Hand_Tools&hash=item3f31cc970a
Also just check with the wheel nuts if the wheels are for tapered or flat wheel nuts, eg R34 gtr wheels are for flat wheel nuts, most are tapered like the link above.
If you need longer studs you can get hold of them too.
if referring to these...
they are outside and 19mm socket too, but lock nut has got plenty of length on it. there are heaps of inside lock nuts, just need to shop around.
with wheels like that, i'd also be careful of how much thread you got available for the nuts. If not much, say hello to longer studs too. yay.
Yeah those ones. They can be done/undone with a 17mm socket (just went and checked) or a 21mm socket over the project mu socket.
yeah sorry, meant 21mm... didnt know they could be undone with 17mm sockets. Thought they were a 7-sided nut so cant us conventional sockets/spanners.
Can vouch for quality of those nuts. can get them cheap on ebay (probably stolen though as $130 is probably below cost)
As mentioned above, these are steel, internal hex and cheap:
http://www.ebay.com.au/itm/BLACK-STEEL-TUNER-WHEEL-NUTS-x20-ROTA-M12x1-25mm-/161233337414?pt=AU_Car_Parts_Accessories&hash=item258a417c46&_uhb=1
Also, are you planning on PC'ing the centres white? They already look awesome!
Thanks guys, will probably go with those internal drive nuts from ROTA, with plenty of camber.
This is what they will end up looking like:
I'm pretty happy I managed to find these in the size I wanted, it's about a close a match as I could hope for.
  • Like 2
You must be happy with those wheels man
I thought the brake caliper clearance looked good from the pictures.
You'll have to measure them up and see what the specs are, they look very tasty!
For the wheel nuts, I bought a set of the internal hex type from Ozzy Tyres for $50 with the tool, Jax, Bob Jane etc all seem to sell these for a similar price
I used them on my last skyline (mainly track) for 18 months without any issues, I'd recommend trying them.
Awesome build too, glad to see it progressing and getting some track time too.
What sort of tyre will you run? and size?
I have someone that can fabricate the center lock adaptors for you.
Ill be doing the same thing for a set of BBS E88 from a porsche 996 RSR.
Would be nice to know the size and offset of these.
I found the perfect wheels to finish this off ... just one problem you only need 4 wheel nuts !
http://page13.auctions.yahoo.co.jp/jp/auction/r109787797
These are awesome. Gotta make do with what I've got!
A couple of shots with some camber dialled in. I think the rears have a bit too much camber so we're sending it to east coast suspension to dial it in
10251887_10154035599455301_8892004708262
1982192_10154035599470301_2064742932121110256222_10154035599460301_876287765251610174998_10154035599465301_4020493031545
  • Like 2
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
