At the time I was happy to buy a clean mostly std 96 without ABS , just more crud you can't legally remove and expensive boxes that can fail . Couldn't escape the drivers handbags though .
If I had to rebuild a 25 short I'd use Neo style rods pistons and lid .
A .
Nope, though I personally wouldn't go for the HTA2868 twins that are available - I doubt the combination would match up overly well to an RB... especially when squeezed into those little housings. Owen Developments sell them though, and someone installed a pair on his GTR but then had an engine failure which set him back something fierce so not sure if or when that will be back together. It seems folly to me to try and push past the "-5s" flow at this stage in those housings, I guess the closest to a setup like that which I would like to see would be more like upgrading low mount T517Zs to use the 68HTA wheels, probably less likely to surge and generally be a better match.
Fair point. I had a feeling that little rear housing would/is the bottle neck. -5's it is then!
What would be nice would be an HTA equivalent of -9s IMHO, something that flowed a bit more than -5s but spooled better than any low mount bolton option currently available. Wonder if the would bite :-D
Sent from my GT-I9505 using Tapatalk 2
ata-cid='6899132' name='Piggaz' timestamp='1371733825' post='6899132']
I actually thought something along those lines after i posted it. Same peak figure flow of a -5, just come on even earlier. I would be so down for that!!!!!
Never satisfied :P
Don't even know if they make something like that.
Nothing really has happened for the low mount GTR setup for years.
Unless you have a 35gtr :ph34r: they have been making some crazy numbers lately with the HTAs
Because going to a bigger single is winning - and it seems people are more keen on winning these days :D Twin scroll HTA3586 would go nicely! ;)
I have no doubt that a well matched single would yield a better result... Just can't give up the "standard look" :/
^ just black everything like Mat, for ninja stealth look lol
Lol i think Paul killed mine in terms of the stock look..... But mine is :ph34r: spec..... I was originally going to do the front housing of the turbo BUT it looks too good and i am kidding myself if i think i can hide it :laugh:
Yours looks more stock than most RB25DET engine bays, defect free I guess?
then again it depends on the copper :)
I've been pulled over in my shitbox and popped the hood. I told the copper it's stock and he was like yeah it looks pretty stock to me, close bonnet.. happy days.
Maybe the stock airbox saved me from a defect, hopefully be getting turbo/manifold by Q3 after my tax returns hehe
A low mounted 6boost I think could almost get away with it, I just need a heatshield made up and it will come as close as it gets I think.
If you are fouling the front housing on the 3037 then the HTA version wouldn't have much chance as it has a bigger front cover again, i should have got a side by side pic but i didn't think of it at the time!
I even asked you to :P On that note, DYNO PLOTS???!!! :P
I think it could be done, engine mount moved/modded but its a PITA
You have done an epic job! Hurry up and get results ;)
Did you? Oops...
I sent an email and Adam will do it when he gets a chance :) You waited this long, so wait some more hehehe
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
