I am after people’s opinions and recommendations for head gasket, intake manifold gasket and exhaust manifold gasket.
They are to suit a RB25DET/RB30 build, the intake manifold is going to be a custom made one, and the exhaust manifold is a sinco custom.
I am thinking either a cometic or permaseal, or is there another option I should be looking at? I am keen to hear people’s experiences and thoughts.
https://www.sau.com.au/forums/topic/426736-gasket-recommendations/
I have a Tomei steel head gasket. the advantage is I have been able to remove the head and replace it twice using the same gasket. I see no reason why cheaper ones shouldn't be perfectly satisfactory though.
Yeah, the thick rubber gasket, i have the stock manifold and now im going to try a cosmetic gasket
It was fine with the small highflow at 18psi but the GTX3076 with 18psi and it leaked, then with a new OEM gasket it leaked again.
Edited by AngryRBGTX
More time to add to previous post
SAU Trader JDM Auto Link http://www.jdmautolink.com/p/nitto.html
Get good prices. Check the gasket kits out
I run JE/Nitto Pistons, Oil Pump, Drag Metal head & In/Ex Gaskets in my built 26
Overkill for my current power level, but I wont take the risk of another rebuild :no: and ready if I feel the need .....
Small investment compared to an engine rebuild. Not much compared to what your going to spend during your rebuild either.
OEM if your not chasing big power and running large boost
My engine builder built one of the first 1,000hp Rb26 engines in Aust many years ago using a OEM head gaskit with no issues.
I normally use Tomei but the builder insisted on OEM for his own reasons, 21 psi and 3 years later haven't had a problem.
if you think you're going to be pulling the engine back apart, use mls(multi layered steel) gaskets.
can be had in a couple of brands.
tomei
cometic
nitto
nismo
im using a cometic mls headgasket.
and I have now reused it after spinning bearings and needing a rebuild.
in saying that, im also using oem for the rest of the gaskets throughout.
if you want to support Australian business, go with nitto.
im pretty sure they are an Australian company.
and from what ive heard, they are very good with aftersales support.
either way, good luck with your build.
Only use a steel shim gasket if your having the block and head shaved so that it is flat. Be sure to spray the gasket both sides with 2 coats of hylomar when installing it. Otherise you'll end up with water in oil of vis-versa.
You can't beat an OEM gasket for seal of fluids. The OEM gasket will absorb 3 times the amount of surface variation of a shim gasket. If you combine this with o-ringing the cylinder block, head studs and a propper tune, it will handle all the boost you can throw at it.
Im using an OEM gasket, setup with extra crush on the fire ring (o-ring style) and am running 1.75kg/cm boost. I've had it up to 2kg/cm but have run out of fuel at around 5500 rpm. A problem soon to be resolved with a bigger fuel system.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
