They opened last night :)
Same problem I've always had with them. The clips fall off and come out in the oil. Cruchy for a while then, the selector fork breaks sometime after.
Would that be different to the busted 3rd gear i had? The gears were notchy at times but not constant... The 34 boxes are slightly different to the 33 from memory but now sure how...
I'd assume it's the same, the 34 boxes are pull type and the 33's and push type that's the difference. I think.
Bonnet venting looks dramatic - love it. Lift it and show the work on the underside.
Wondering if the first few rows would be the ones you really need. Hoping that the louvres past half way along don't work against the goal of releasing air. That's starting to get into the high pressure area as you approach the windscreen base.
Yeh so we took a little trip over the border for some more track time. They ran the extended circuit, so it was hard to compare times.
But the split times are on par from last year, so the cage hasnt changed the performance.
Noticed the false floor you put in under the pedals. How did that go? Looks like yove fixed it directly to the floor however others that ive seen have been about 5cm above the floor. How have you found it?
It's just sikaflexed down. Seems fine.
  • Like 1
We broke another gearbox over the weekend. This time 3rd gear is no more.
This box was a rough one to start with anyway.
I've got a better one at home that I'll have the synchro clips replaced, hopefully it lasts a couple of years before needing attention.
We still came second with a 1.05.28, slower than last year. But then no-one went faster than last year. Cold track surface conditions both days.
I'm sure with 3rd gear on day two I would have gone a few tenths quicker. Still not the 1.03.xx that Benny's S2000 did last year, but maybe a mid
  • Like 1
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
    • I spotted a black C34 in Mittagong this morning!
