TUF250 Posted June 25, 2010 Share Posted June 25, 2010 hi guys, just some feedback for the thread... I picked up a NGK OZA395-E2 from bursons the otehr day. Only $100 RRP Direct fit, same connector adn even comes with a sealant on teh thread so need to buy gasket goo. Seems to work really well Cheers Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5313621 Share on other sites More sharing options...
pipster11 Posted June 26, 2010 Share Posted June 26, 2010 can i sak what ppl are doing for r34's? i'm pretty sure someone told me that the plugs a different but the sensors are the same size mine is still cycling high to low but sometimes it hangs and kinda gets "stuck" for a couple of seconds do i grab a falcon one? or kudos r33 one and cut and shunt the plug? cheers, Tom Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5314037 Share on other sites More sharing options...
Spring&WateR Posted July 2, 2010 Share Posted July 2, 2010 Hey guys is there an O2 sensor in the exhuast as well ? if so does it have to be changed at all ? Ive already had the one in the engine bay replaced... car still running abit rich and this is after a tune as well hmmm Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5324817 Share on other sites More sharing options...
heller44 Posted July 2, 2010 Share Posted July 2, 2010 No. They only have one, in the dump pipe itself.The other sensor in the cat is just an overtemp switch, cat gets too hot it turns the idiot light on. Only the '26 has two. Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5325571 Share on other sites More sharing options...
Spring&WateR Posted July 3, 2010 Share Posted July 3, 2010 sweet thanks Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5326857 Share on other sites More sharing options...
PhilKenSebben Posted July 28, 2010 Share Posted July 28, 2010 Picked up a new one for my ECR33 today from Auto One. Brand is Walker, $120 and is supposed to be direct fit. According to the box, it's the same as an N14 Pulsar 2.0? Part no. EGO-018 HAVE NOT tried to fit it yet, will do it on the weekend, but the plug certainly looks the same. Even came with a small tube of anti-seize for the thread. Groovy. Took photos but my DSLR takes photos that are around 7MB each, so stuff it, you'll live. Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5371518 Share on other sites More sharing options...
boiracer Posted August 1, 2010 Share Posted August 1, 2010 lol, same questions over and over. get one regardless of if you think its stuffed or not, chances are it needs replacing. see Kudo's, cheapest and easiest way, they have them for most models. made a world of difference to my R33 S2 Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5378182 Share on other sites More sharing options...
XMOr33skyline Posted August 16, 2010 Share Posted August 16, 2010 I get woeful fuel economy. like 300km to a full tank. would it be the o2 sensor? if so, where can you buys these from? JaFF i get 200kms a tank Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5402406 Share on other sites More sharing options...
Wacky Dee Posted September 24, 2010 Share Posted September 24, 2010 before wasting money on o2 sensor and all the other junk ... try inflating tyre pressure to 40PSI. I did that and also changed my coilpacks a couple of months before and used 2 bottles of Nissan injectory cleaner ($10) my 90% stop-and-go-traffic consumption went from close to 17k/100Kms to 14l/100Kms. I don't know which exactly but I suspect tyre pressure (lower rolling resistance) + injector cleaner did the job. Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5463505 Share on other sites More sharing options...
KrazyKong Posted September 24, 2010 Share Posted September 24, 2010 New O2 sensor and plugs gave my car a massive difference in fuel economy. It never hurts to do the tyre pressures and injector cleaners too, but if you havn't ever replaced your O2 sensor and plugs, do it and you'll see the improvements. Another vote for Kudos. Great price for their O2 sensor and no re-wiring required. Just plug it in and you're rolling. Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5463770 Share on other sites More sharing options...
Moodles2 Posted September 24, 2010 Share Posted September 24, 2010 Thing about injector cleaner or any additive, you run the risk of damaging the O2 sensor(s) in the process. Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5464205 Share on other sites More sharing options...
KrazyKong Posted September 26, 2010 Share Posted September 26, 2010 Really? I've never heard injector cleaners damaging the o2 sensor before. Do you have a link for more info on this? Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5466150 Share on other sites More sharing options...
Moodles2 Posted September 26, 2010 Share Posted September 26, 2010 Just have to make sure you buy a injector cleaner that is marked as O2 sensor safe, O2 sensors don't fare well against additives such as octane boosters etc Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5466229 Share on other sites More sharing options...
KrazyKong Posted September 26, 2010 Share Posted September 26, 2010 I havn't used any octane boosters but have used some Lucas injector cleaner. Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5467038 Share on other sites More sharing options...
DuFFR32 Posted October 2, 2010 Share Posted October 2, 2010 O2 sensor related, I recently bought an engine to swap into my car sometime soon and it had an O2 sensor in the standard dump pipe and looked better then the one i had in my car atm, so i swapped it over with my old one. Now my car runs like shit. it stutters and coughs and wont go anywhere, i throttle it a bit, coughs, then really light throttle it goes normal again, cant even go past 2000rpm then it coughs and splutters and the turbo sounds really weird. Im going to go for a drive up the street now with the O2 sensor disconnected and see if it changes it, also do i have to reset ecu with a different o2 sensor? (nistune ECU) another thing, When its cold (overnight cold) it goes into a weird choke mode? it makes me put my foot down heaps more than usual and you can hear the turbo spooling up heaps loud, the car only starts moving when the boost pressure starts to go past 0, (then i have to back off the throttle as boost+cold engine = bad) its so hard to explain, the ecu stays in this mode until the engine gets up to temp (ie. halfway on temp guage) and while cruising along in 4th at 50km and its up to temp you can feel the ecu turn this mode off and the car runs sweet again. Anyone else have these weird issues? Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5476060 Share on other sites More sharing options...
daineisdabomb Posted October 3, 2010 Share Posted October 3, 2010 Granted that it measures heat only, which is common knowledge, it IS an oxygen sensor. no mate it isnt. it measures the temp of the exhast gas in the cat because a catalytic convertor only works at a certain temperature. also to the dude that said his a/f ratio of 14.1/1 is lean, actually it is slighty rich. 14.7/1 is the perfect mix (stoichiometric mix) where every atom of air and fuel combines and burns (as long as ignition timing is correct). 14.7/1 is the optimum cruising ratio. Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5477624 Share on other sites More sharing options...
pipster11 Posted October 31, 2010 Share Posted October 31, 2010 Just stumbled upon this http://www.cats-direct-shop.co.uk/lambda-sensors.php so cheap, can anyone confirm what size our o2 sensors are? Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5525620 Share on other sites More sharing options...
R3N3 Posted February 4, 2011 Share Posted February 4, 2011 i bought my sensor from kudos (great service). once installed, this thing made a HUGE difference. i just recently did a 3hr drive (on the highway) and i averaged 11L per 100 ks (using consult). last time i did this drive it was well over 20L per 100Ks. even city traffic driving im averaging 13L per 100ks. so it has already payed itself off in fuel Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5655851 Share on other sites More sharing options...
RB25PWR Posted February 8, 2011 Share Posted February 8, 2011 Right now I'm also getting woeful fuel economy. Dunno what it is but I know it's disgusting. Something that has always irked me about my car is that the temperate gauge needle NEVER sits in the middle. It's half way between the middle and C once warmed up. I presume this isn't normal? What does this mean in relation to the 02 sensor, anything? Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5661837 Share on other sites More sharing options...
jrm Posted February 8, 2011 Share Posted February 8, 2011 Right now I'm also getting woeful fuel economy. Dunno what it is but I know it's disgusting. Something that has always irked me about my car is that the temperate gauge needle NEVER sits in the middle. It's half way between the middle and C once warmed up. I presume this isn't normal? What does this mean in relation to the 02 sensor, anything? I would imagine it has nothing to do with the O2 sensor at all. However, if your car is not getting up to operating temperatures (water temps should be about 60C for 'operating temperatures'), then the ECU will be in cold-start mode - which is much richer (to warm the car up faster), and this richness results in poor fuel economy. This could mean you have an issue with your cooling system (thermostat/radiator), or you could just have a dodgy coolant temperature sensor. Shouldn't be too difficult to diagnose, either way. If you have access to a USB CONSULT cable (about $50), you can probably tell if its the gauge or something more (it'll let you read the coolant temperature directly from the ECU). Link to comment https://www.sau.com.au/forums/topic/43095-o2-sensor/page/21/#findComment-5661936 Share on other sites More sharing options...
