  • 1 month later...
  • 1 year later...
well if anyone of the NEO ppl were hesitating about doing it, there is no excuse now
http://www.ebay.com.au/itm/NEW-3-Wire-Universal-Oxygen-Sensor-O2-Easy-Fit-Kit-/120737660086?pt=AU_Car_Parts_Accessories&hash=item1c1c867cb6#ht_3120wt_1244
i bought the r33 one and cut the plug off (tried to be tricky and pull the pins out and swap them but they are slightly bigger in the r33 plug)
wish i had seen this, looks like the same sensor but cheaper again!
with the r33 sensor installed i got under 10l/100kms on the drive from tas-gold coast (yesterday)
Have any more Neo people run these? Looking to potentially buy one as my factory plug on both harness and O2 sensor have melted so would be much easier install with this kit
i was reading this topic the other day was through i would change mine in the stagea.
i change the sensor still dont know if it fix my fuel economy. driving around like normally
and it still used alot of fuel. i got a ngk one from ebay through...
That's not too hopeful. I think my current O2 sensor is ok and will be trying to do a direct wire in this arvo but if I have any problems was hoping to grab that ebay one for $40
  • 1 month later...
So I have never had any problems with fuel economy in my car but went and got it tuned today and the tuner actually turned the O2 sensor off because it was going spastic.
He showed me on the computer once the throttle is touched the O2 sensor went from nothing to max voltage straight away and just generally all over the place.
I tried to directly wire my O2 sensor in the other day could this be a stuff up with my wiring?
  • 9 months later...
tested my o2 sensor today, c34 stagea at warm idle to 3-4k revs i saw 0.3 -0.45 while parked. multimeter grounded in rocker cover and positive probe on black wire on o2 which is the thick brown wire on loom.
not sure what i'm looking for to confirm its stuffed other then it not alternating, unless i'm ment to be seeing more then 0.5v with no load parked ?
who can confirm?
^ thanks noted, just not sure if they can be half stuffed or it will work 100% and just not work at all if broke.
might just grab a universal 3 wire sensor from vulture for $40 as they are ment to be changed a bit like spark plugs , i assume the thread on the dump pipe is the same for r32-r34 gtst?
Edited by Dan_J
R33 and Neo are different
And then pay a little more and get an innovate wideband that has narrowband simulation for your ECU. Win win :)
Johnny are you using your WB as a NB simulator? If so how did you go about wiring it into the computer?
My NB has just blown so I going to use my techedge to simulate, it also has a function where I can alter the lean/ rich points so I can adjust stoich up or down for different fuels, or so I can target a leaner AFR
Wouldn't mind setting it up to hold 16:1 in closed loop, just to get better economy on cruise.
^ hey mate, I disconnected my narrowband in the engine bay and spliced the narrowband output from the innovate straight into the ECU harness.
There's no need to hook up the sensor ground and it worked really well. Not the first car I've done it to also, one thing I've noticed is that it "appears" to hit stoichiometric much quicker than factory narrowband O2s
Give it a crack you can't go wrong, in saying that I'm now running full closed loop fuel control with my wideband (running stand alone now woots)
I usually keep it stoich anything in vacuum up to atmospheric pressure (0.0psi), on cruise I'm a little cheeky and let it sit at 15.2
Best I've gotten out of 50L was 540km with the occasional squirt when I drove to Foster and back on 98 with the AC on most parts
So when in closed loop I get a hi reading of 15.23:1 and a low reading of 14.39:1 for and average of 14.8:1
Did a run to the gold coast on the weekend and got 8.9 L/100Km ~ United P100
Might have another play with it and try to get an average closer to 15:1
Edited by Missileman
^ great job on the economy side - on very load & cruising RPM you could even lean it a a touch close to 15.5 if you're after economy.. however drop back the timing a little so keep the cylinders happy.
    • Thanks for sharing. That's a great video! My buddy is doing the same thing on his build (S chassis struts and towers). He's building an S14 with billet RB30 shooting for 2000whp... a race car with a TH400 just like this video. For a road car I just couldn't go this route as the strut has to be almost vertical and the caster is not going to pivot correctly (let alone camber gain). You think the R32 frontend is bad, wait till you put a MacPherson strut on without modeling it all in Solidworks to check geometry. I'm not saying it's a bad way to do it but I'd be really curious to see how it affects the geometry.
    • Hey Christof and welcome!  Sounds like an awesome project! I'm not sure many of the regular users on here would know much about the HK but I could be wrong.  Looking forward to updates.
    • As long as its NOT a HyperSHITtune, youll be fine.
    • First time visitor and currently getting ready to start work on my HK Premier.  Its all stock, 186 with 3 on the tree.  The only mod i have right now is extractors.  I am hoping to get some guidance on slightly modifying the engine to bring a little more power. Just going for a nice, comfortable cruiser.  The car is very straight, however i have been out of the country for 20 years and its been gathering dust at a family farm.  Will be doing quite a bit of body work to cut out some small rust areas (frnt quarter panels and a few other small bits) and fix up the paint.  Will be redoing the interior (its currently black and the seats are in real need of recovering and respringing the driver side (its front bench seat).  The dash needs a little TLC, but no real damage.  As my heater has degraded I am considering fitting something after-market that will be both heater/AC (recommendations here are always welcome). Wanting something discrete that will allow me to use the same controls and not be obvious once inside the car.   For the engine, i have been told i could consider upgrading my cam (imagine i would need a new head as well) and putting a new carby (currently the original stromberg).  However not sure what is going to be the best route.  Would certainly welcome any comments/suggestions.  As  a final step I am looking at changing the wheels. Current hubcaps are in dire need of refurbishment or replacement (imagine its a bit like hens teeth).  Thinking of some clean/classic looking mags (7-inch should be more than enough - not going for a large change in look).  Welcome any comments/advice and of course any questions.
    • I got the ARC M079 due to the space constraint.  Been running mint for the last 3 years.  Plazmaman also seems like a really solid choice but not used myself.    Hunt around for a better price but this is what I have - https://www.rhdjapan.com/arc-brazing-intercooler-smic-m079-bnr32.html
