Nah nah, I think Kat's looks superb Richard.
I just wouldn't do it on an N1 or an ADM > Hakosuka badge - minimal and subtle for the time being.
The BNR32 is the only GT-R that didn't come out with a front grille badge. Why was that?
Another pic...
  • Like 1
Another pic...
I spy with my little eye I see a nismo sticker on the boot :woot:
Yes Chris, the BMCC restricted our building to regular size garage spaces being as close to legal wrt neighbours' boundaries. About to extend a carport at the front now to accommodate Maria's SUV. Where there's a will...
Yes Nismo logos. Wongy is trying to get me the old style Nismo mats atm too. Much appreciated for comments fellahs.
I love that strut brace Terry.
But not with a standard Motor :/ It looks out of place or something i dunno. Got any more pics?
for that engine bay a HKS Kansai painted the same as your rocker covers would look amazing.
Nup, no more pics just yet Anthony.
Sometimes these things just 'grow on you'.
I'm still keeping the black Nismo one for the time being.
I must say that the brake master cylinder stopper is a nicer fit on this Fujimura than the Nismo though.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
