Stretch lol, you get around the forum if I got it right :)
Rims are Advan RS-Ds 18X10 the tyres are 255/40 but have a set of Yokohama 265/35 AD08Rs ready to go on after I get the car back and use up the rubber on the car now :)
255/40s on an 18x10 rim :blink:
I too call you stretch
Stop mucking around and put those AD08rs on
haha, I thought the stretch was from a wasteland thread I was playing on :)
The tyres were on the car when I bought it and as the car has been living away from home most of the time I have not bothered. I want play a little bit when I run it in before I put the AD08Rs on.
I wanted 275/35 but they do not make a 275, just 265 then 285 ?
solution was simple.......should a got 285s :P
I know now :(
BJ said these 265s are the recommended size and I was not sure about the 285s but they do not last forever and if I like them, next time :)
what model you got mate?
R33's you can get away with fitting nice phat tyres but the R32's not so much
Yeah, gota call and could have got them for $220 as they got a lot in and trying to flog them :(
At first I was looking at going to 19x10.5 with the 285s but for whatever reason I changed my mind, cannot remember why, too much red maybe :)
When you are going through a learning curve with these cars it is not easy with anything you want to do, brakes and tyres are amongst the most confusing :/
But everything can become confusing and the more you read the worse it gets. In the end you have to make your mind up what you want from the car for yourself, then make the choice and hope it gets you what you want, it can be a costly choice if you get it wrong, lol
I totally understand what you mean. I've been there.
However you can only try to do what you think is right.
Sometimes you get it wrong but that's how you learn.
Talking to peeps in the business is sometimes the best thing instead of researching
After researching for ages I did speak to like mined blokes on SAU on just about everything I have done so far, then researched the info given. But they still have their preferences but a great guide to know what they have done has produced the type of results I wanted.
After I was sure what I had done to the car was not getting me the response I wanted I decided on the Nitto 3.2 stroker.
I kept everything from the earlier mods I did except the cams. I am sure I can get a lot more from the car but I do not need it :)
Probably went into over kill with the drive-train, but it all sounded soooooo GOOD :)
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
