RB 26/30 built by ProEngines. 9:1 compression, Cometic head gasket, Supertech pistons, Oil restrictor, ARP Head Studs, ARP Main studs, Argo rods, ACL race bearings, Crank collar, Balanced, Crank grub screwed, Upgraded valve springs, os intake valves, mild porting, RIPS sump adapter, oil pickup and baffled extended sump, Nitto oil pump, new -5 turbos genuine Garret with fabricated support bracing, ported exhaust manifolds, Nitto hot and cold side gaskets, ATI balancer, Twin turbo divider plate, ceramic coated turbo heat shields, braided and insulated oil and water turbo lines, oil return from head to sump, , Nismo injectors, extra PS pulley fitted by CRD, CRD spec cams ground for 26/30, Tomei cam wheels
PMC plumb back catch can
Splitfires
New coil pack loom
New CAS
044 in tank pump with 12V direct feed
Reconditioned front diff
Hicas lines, solenoid etc removed
PMC Hicas locking bar
Reconditioned brake booster
Trust long waste gate dump pipes modified by RIPS to suit RB26/30, ceramic coated and wrapped
HKS Super Drager Exhaust with stainless cat
Modified stock airbox
Just Jap 100mm FMIC
Just Jap ally radiator
Koni revalved shocks with King springs
Bilstein ‘Sydneykid’ spec shocks
Bilstein PSS9 shocks and springs
Nismo front strut bar with MC stopper and Cusco twin front strut bar
HKS Kansai rear strut bar
New shock rubbers
Whiteline uprated front and rear roll bars
Reconditioned gearbox
Jim Berry Full Monty clutch with organic pressure plate
Resprayed with new body seals, weather strips, rear side glass and windscreen
Momo wheel
Recaro Evo 6.5 seats
S15 Seats (minor modifications to suit)
Alcantara retrimmed headlining
New Nissan OEM trim parts
Sony head unit, splits and upgraded door speakers
Alcantara dash
VDO console gauges
320k/hr speedo
Brembo front brakes, DBA discs, Project Mu Type NS front pads
Brembo rear callipers supplied not fitted
Volk TE37 17x9 +12 offset no damage but could do with a respray
Nismo LMGT2 17x9 +12 offset wheels
Vipec V44 plug in
Nistune board
Trust oil cooler brand new in box
Engine bay main loom brand new in box
All recent work by CRD
Rustproofed
Tuned by CRD 375 awkw @ 23 psi
Fully engineered in NSW and registered as a 26/30
Lots of spares including steering wheels (OEM, Nardi), dashboards, interior parts, rear ¼ windows, window trims, OEM gearknob, Nismo 3” exhaust.
I’ve owned this car for 12 years after buying it from an importer who intended to keep it for himself. He ended up spending more time in Japan than he intended and decided to sell it. Initially my daily driver for 3 years and 50k faultless km. Never tracked. As you can see it’s had significant money and effort spent on it over time to make it fast and reliable. Effort required to make the 3l bottom end fit properly was significant as it's not a drop-in proposition in a GTR, but the result was excellent. When the stroker motor went in it became a fair weather/ weekend car. The price is high but the quality is there and the value of the spares is significant, particularly the suspension / loom / oil cooler and rims. You simply couldn’t build this for anywhere near the asking price. Jim at CRD called it ‘as good a street car as you’d ever want’. Everyone who's been allowed to work on this car has commented on how straight it is.
$34k firm or consider trade for low km well maintained late S3 R8 Clubsport only. Located just north of Canberra in NSW. Pics to follow.
This car at this price isn’t for everyone and I’m no hurry to sell so please no low ballers, timewasters or tyre kickers thanks. Receipts for most work. Don’t really want to part company with it after all the development work I’ve put into it but I just don’t use it anymore. Please PM me if you’re genuine, interested and have assured funds.
  • Like 1
  • 4 weeks later...
  • 2 years later...
6 hours ago, jaysevu said:
did you manage to get some pictures?
Second that.
A friend is looking for a R32 GTR. Photos will help.
Cheers!
Interested in Photos, has anything changed or been added from the modlist and is there a price adjustment seeing as it was written in 2014
  • 10 months later...
Yes this car does exist and it is a work of art! Extremely well put together and a solid car, which will be cared for and pampered during my ownership.
Thank you Scooby32, was a pleasure dealing with you and I will keep in touch.
Car is now sold [emoji16]
  • Like 2
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
