I want the most response possible out of 2860-5 for my r33 Gtr. engine is out, so I want to do anything that would help lag. Ideally getting the -5 spool close to -7 spool
Built engine, staying 2.6
9:1 compression/ e85
CES 3 inch dumps
Twin 3 inch front pipes
4 inch cat back
Largest cat
Type b cams
Cam gears
Gts4 diffs
Match port turbo side
Running a PFC, will a newer ecu help with lag?
Anything else to the head I can do, match porting the intake help?
Hard pipe kit help? A little, or allot?
Larger valves a must? Intake & exhaust or just exhaust?
Billet turbo wheel?
It will stay a street car, and twin turbo
What have I missed?
Edited by GD51LA
CES 3 inch dumps
4 inch cat back
Largest cat
Type b cams
Cam gears
Gts4 diffs
Billet turbo wheel?
What have I missed?
Ace tuner
You could go back to 98 to reduce lag but do you want to? lol
E85 EGTs are lower, so theoretically there will be more lag experienced - however you're able to dial in more timing in the mid range so you have a fatter torque where it counts.
Compressed air injection into the turbine wheel.
Water injection into the exhaust manifold or direct injected into the cylinder on the exhaust stroke.
3 phase brushless motor inside the turbo core.
I am sure there are more I have thought of over the years.
You can possibly use a smaller diameter runner exhaust manifold and stock cams and increase the compression upto 9.5..
A good boost controller and tuner too.
Edited by AngryRB
You won't get 5's coming on like 7's, no way.
Put the standard cams back in or spend some coin and buy some form or V cam/ VCT.
As Brett said above, more cubes.
I'm not expecting a spool of a -7 from a -5, just as close as I can go
If I decided on the Brian Crower 2.9 stroker, how much sooner spool are we talking? Up to 500 rpm?
Can you be more specific?
I don't think the standard cams would be a better option than the tomei type Bs, when aiming for 400-430kw awkw
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
