It won't want to putter around, it'll want to turn tyres everywhere!
Paulie Paulie Paulie , you do not have to disappear in a cloud of smoke going to Woollies :)
I am not going to change anything again, if it runs anywhere near what I want, thats farken it, no more of this shit!
Do they have a dyno and a tuner? It should start up and be run in on the dyno and tuned and then ideally you will get another tune when its done about 10,000.
Hi Bob, this is CRD they do cars internationally and have a pretty good reputation. Their work seems tough and stands up to hard driving.
I just cannot handle the time shit, there is no need for it , especially from a company that can do this type of specialty work.
2k is a plentiful run in period.
If I follow instructions, 1000k should do it, but that is like driving home and back to Sydney. I will be working the motor on the way home, about 350Klm, change oil, do another 500 and change again and do some more Ks, book it in and back to Sydney for the tune, hopefully for the last time to do with the car, well that is, if I ever get it back :)
Hi Like, .2L,? 2.6 t0 3.2 = .6L to help off boost ?
Luke has a 3.0, you have a 3.2. Basically means you're gonna have more grunt naturally without the aid of the turbo.
Some movement but the bonnet is back on why do that before all of the motor work is done , it would only get in the way, yes/no? see what has happened, you blokes have got me all paranoid :(
You will likely get a small vid of it running next week.
and you will be off to pick it up
That would be soooooooo GOOOOOOOOOOD!
But I will not hold my breath :(
4 bolts. 10 mins effort
makes it easier to work in the bay. Safer for the protection of the bonnet.
Saying that I see a lot just use an extension type bar on the bonnet to hold it up higher
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
