CRSKmD Posted February 25, 2015 Author Share Posted February 25, 2015 Last BSMCwe did a few spray outs with the paint and had to keep taking it back to the paint supplier as the match wasnt close enough. after the third time going back to the painter the spray out finally looked pretty close.Front end parts with paintRust spot on roof repaired and bogged 1 Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7486666 Share on other sites More sharing options...
timmy_89 Posted February 26, 2015 Share Posted February 26, 2015 Car is looking great! Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7487740 Share on other sites More sharing options...
CRSKmD Posted February 28, 2015 Author Share Posted February 28, 2015 Spotted an S14 steering rack with new ends and boots for cheap. seeing as there was 20 degrees play in the wheel before anything happened . i also had a mild power steering leak. Rack boots were gone and the ends were fairly flogged. After some research i was lead to believe that an S14 rack was a direct bolt up to my R32's (SPOILER: it wasnt) and should be a 2hr tops job. It took me about an hour to get the old rack out and the new one in. there was just a slight issue with the power steering line fitment... DAY 2 of a 2 hour job As it turned out the power steering lines on a factory NON HICAS 32 are very different to the lines on a HICAS model. NON HICAS both lines for the rack run in front of the cross member. HICAS has one line in front and one behind. luckily the seller of the S14 rack also had a set of Hicas lines and i was able to get the rack and lines in place with some mild modification. Also tried to fit up a clock spring so I'd have a horn. notice the issue? so far not everything was coming up Milhouse. not at all. Went back to the rack and tried to adjust it to close enough before driving to the wheel aligners and i ran out of thread on the tierods before the wheels were remotely straight. (previous owner had extended LCA's and changed tie rods to suit.)I sourced a set of correct length ones and while under the car i noticed this had happened. Day 3 of the 2 hour job I replaced the slave, got the wheel alignment done and took it for a well deserved drive. 2 Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7488613 Share on other sites More sharing options...
CRSKmD Posted March 6, 2015 Author Share Posted March 6, 2015 With the front end components painted had having had time for the paint to harden up a bit it was finally time to fit up the front end. went to the car wash and gave it a quick spray off. Fitted the grill + some bolt on spacers to fill out the guards 2 Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7491987 Share on other sites More sharing options...
GH05T Posted March 6, 2015 Share Posted March 6, 2015 noice Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7492020 Share on other sites More sharing options...
Dylan454 Posted March 8, 2015 Share Posted March 8, 2015 What size spacers did you use ? Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7493215 Share on other sites More sharing options...
CRSKmD Posted March 8, 2015 Author Share Posted March 8, 2015 What size spacers did you use ? ended up with 25mm. 20mm would have been what i was after but this is what came up effective front wheel size is now 17x9 -3 haha Probably can drop back to 20mm once i adjust some camber out of the front end Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7493296 Share on other sites More sharing options...
CRSKmD Posted March 22, 2015 Author Share Posted March 22, 2015 (edited) Some photos from All Japan Day 2015. all photo credit to the photographers getting it ready. i also got a daily Hopefully now that i have a daily i can focus more time and attention on the 32 for mods, without the rush to get it back on the road to drive to work Edited March 22, 2015 by CRSKmD Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7501261 Share on other sites More sharing options...
GH05T Posted March 22, 2015 Share Posted March 22, 2015 car looked good on the afsr cruze Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7501472 Share on other sites More sharing options...
CRSKmD Posted March 29, 2015 Author Share Posted March 29, 2015 car looked good on the afsr cruze Cheers mate. i got a photo of you taking a photo of our cars Currently im on the fence about what do to body wise to my car. rego runs out soon and im toying with the idea of fixing the dents and other damage and giving it a full repsray. but not sure if its worth doing...? Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7505482 Share on other sites More sharing options...
AngryRB Posted March 29, 2015 Share Posted March 29, 2015 GTR front end is awesome, nice build Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7505729 Share on other sites More sharing options...
CRSKmD Posted March 30, 2015 Author Share Posted March 30, 2015 GTR front end is awesome, nice build Thanks man! always nice to hear feedback on the car 1 Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7505920 Share on other sites More sharing options...
AngryRB Posted March 30, 2015 Share Posted March 30, 2015 (edited) Bonnets like a mirror, nothing like a great paint job, its hard to go backwards with an RB , I have dreams of a 32GTR they look tough even after 25years.. good to see you've taken it out on track, mine hibernates in the shed waiting mods Edited March 30, 2015 by AngryRB Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7506277 Share on other sites More sharing options...
CRSKmD Posted March 31, 2015 Author Share Posted March 31, 2015 Bonnets like a mirror, nothing like a great paint job, its hard to go backwards with an RB , I have dreams of a 32GTR they look tough even after 25years.. good to see you've taken it out on track, mine hibernates in the shed waiting mods yeah the front end is mint thanks to Pearl Factory sadly the rear of the car has seen several track days and 2.5 years of daily life (carpark dings etc). thinking of putting mine in the shed to fix the rest of the body work up to be as clean as the front end...but still undecided Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7506988 Share on other sites More sharing options...
AngryRB Posted March 31, 2015 Share Posted March 31, 2015 yeah i guess you have to draw the line somewhere, mine got put in shed and now i havnt even driven it for 12months best to enjoy it i reckon, id rather spend the money on performance unless its really bad, no fun when its stuck in the shed Keep up the good work Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7507004 Share on other sites More sharing options...
CRSKmD Posted April 21, 2015 Author Share Posted April 21, 2015 yeah i guess you have to draw the line somewhere, mine got put in shed and now i havnt even driven it for 12months best to enjoy it i reckon, id rather spend the money on performance unless its really bad, no fun when its stuck in the shed Keep up the good work yeah currently the rear end resembles a cleanish drift car...and the front end is fresh 2 pac paint also the colour match isn't perfect haha. just eats at me. so now the next question is keep it blue or full colour swap? if i kept the blue i want a similar colour but more metallic. for any colour i don't want custom i want a factory colour so it easy to get more of if need be Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7519896 Share on other sites More sharing options...
MC-WOSHY Posted April 22, 2015 Share Posted April 22, 2015 Awesome build man! Read it all and it's definitely come a long way Good to see the potential of a car when in the right hands! (Unlike when you previously bought it) Keen to see more updates as they come mate Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7520620 Share on other sites More sharing options...
JustinFormosa Posted May 16, 2015 Share Posted May 16, 2015 This is great, Loving the work you're doing keep it up Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7534923 Share on other sites More sharing options...
CRSKmD Posted June 16, 2015 Author Share Posted June 16, 2015 Re registered the 32 and after a few grumbles from not being driven for over 2 months (still started regularly) we got it to start.New plugs and a set of Splitfires in and it ran well. Immediately went for a test drive.after only driving the 3cyl power house that is my daily this was a bit of a difference! During its time off the road i purchases a pair of genuine Bride seats + a nardi. will post pictures of these at some point soon 2 Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7551383 Share on other sites More sharing options...
CRSKmD Posted July 18, 2015 Author Share Posted July 18, 2015 Brides and nardi in. next up for interior is fix broken trims, gauges, and a better gear knob. safe to say decent seats really transform the driving experience for the better Link to comment https://www.sau.com.au/forums/topic/452522-r32-sedan-grip-and-drift-have-my-cake-and-eat-it-too-build/page/3/#findComment-7569443 Share on other sites More sharing options...
