Things don't seem to be necessarily optimal, but I'm not expecting to see miraculous improvements in power - perhaps some improvement in power delivery if it turns out the intake cam proves to be excessively retarded in practice.
I also do not expect any real over all power improvements. What I have is plenty.
What I would like to know is, if you have your intake side retarded by 3 or 4 degrees and you advance it 3 or 4 degrees , there is 6 or 8 degrees difference, what would this do for the low end power gain at lower rpms.
Never heard of an external wastegate opening due to exhaust pressure tbh, I'd consider it a design issue if it did - by function definition they are meant to block any flow until the reference pressures met targets - especially if it had both ports utilised.
If he is bleeding off a 12-14lb spring and has a higher than expected exhaust manifold pressure at wot due to a restrictive rear then the gate will crack open, no question. This always happens in this scenario, not the first time and it won't be the last.
With a larger higher flowing rear there will be a lot less manifold pressure at the same boost pressure, even running a 1.15 AR at 30psi I would expect to see less manifold pressure due to the lack of back pressure.
Just curious, if it was getting valve float in the top end, would you/could you tune around it by dropping the boost and retarding the cams?
The dyno curve looks like it gets a wiggle on a touch, maybe not significant?
It won't be floating. I run the same cams, springs and retainers and have given my setup 30 psi.
Not sure how much more boost you want to pull out of it. It's dropping to 18 psi as is.
Theoretically yes but really this is usually the last thing you do after the rest of the set up is A OK.
I think he was more leading towards that being a possible reason its like it is.
How's the water Pete?
When is it booked in for the next tune?
Hi Mark, waters all good :)
Just waiting for some other work to be finished in the shop, not much use leaving it there until he can work on it , maybe another week or 2. Not just the tune to do and I can still use the car while I am waiting :)
I've got to say I would be pretty unhappy with that boost drop.
Kind of like getting married to a hot Virgin, and then being told you have to use a condom for the rest of your life......
Yeah a bit of bummer :(
I will still take the Virgin , condom and all :)
If it's the turbo selection that is causing these issues.... Everything else is irrelevant. See what the new tuner says.
Fairly narrow minded, all you can say is its the turbo. Its rated for over 700hp ffs, if there are no other restirictions it should acheive close to that.
Can u tell me why my engine with a .82 rear housing does not have this issue?
  • Like 1
I am starting to agree with the plausibility of his theory - I wouldn't go so far as to say that's the issue, but.
You have a .82 open housing, a .84 open housing is a different beast and in most cases I would expect it to be more comparable in to a .6x open housing which would make people shit themselves if it was said that someone was going to put on a 3.2 litre aiming for 400kw+ on petrol.
When I first heard about this I thought the hotside was going to be too small and that was before I learnt it was a small divided hotside on it, I've never thought about or had to deal with a bad turbo match like this causing excess back pressure - I like to think all the things I have been involved with have quite well matched turbos and as such exhaust manifold pressure has tended to be sane and never thought about the effect on the waste gate but the more I think about it the more it makes sense. Always nice to learn something :)
Hope your right :)
I spoke to the bloke at Precision Turbo and he said it "should" not loose more than 50HP with the 3.2 . With some blokes taking these turbos up to 740HP with varied sized motors ? ?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
