This is on 98 Pump
Here is the overlay of the car as it arrived.
If i hold the car at 3300rpm under load i can get 20psi.
This dyno run is seeing 22psi at 3950rpm and revving to 7000rpm in 5th gear
The Pic is an overlay of the run he did when I dropped it off (green) and today (red)
Not sure when the E85 will be done?
  • Like 2
Thats a f**ken epic result Pete!
You're gunna be in for a shock now when you drive it on Petrol let alone E85 lol!
Expect near the 500kw zone on E85 mate.. Congrats and well done to Jezzabelle and the boys sorting out the horrible mess you had! Cant wait to hear your thoughts when you drive it now!
Edited by Mick_o
  • Like 1
Yeah Mate, I knew it was a heap of shit the way it was, and I think this proves it :nyaanyaa:
I think I might start using the seat belt now :woot:
Don't forget your adult diapers as well as that seat belt!
Yeah i always knew it was POS when i saw the dynosheet let alone your impressions of how it drove!
You wont want to get out of it now mate!
So he changed the turbo rear? Good thinking
No, the PT6266 was on it all the time, it was not the PT6262 that was supposed to be ordered, this was the thing I said I would post at the end, but I waited for someone to see it on the Dyno Graph.
When I posted the pic of the 6Boost being installed I had an email from the old builder saying , oh you might notice the Turbo is a different model, I said yes it was noticed and he said that he told me about this when the build was being done, I said I think I would remember that, he said I might have been pissed, good call but that is something I would remember , well , I would think I would remember, hic hic
But all good as it is a better Turbo for the job on the 3.2 , but not for the 2.6
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
