no matter the details of this, most will look at it how it is, its was at CRD for a bloody long time, they built it so good on them for that but they didnt deliver the final result, and in alot of peoples minds that is what counts!! call it how it is... the JEZ kicked ass with it, you'll have some wobbly knees in the next week when you drop the hammer pete, so jealous right now...
  • Like 1
Well done Pete, great result!!!! Am looking forward to some vids :D
When I posted the pic of the 6Boost being installed I had an email from the old builder saying , oh you might notice the Turbo is a different model, I said yes it was noticed and he said that he told me about this when the build was being done, I said I think I would remember that, he said I might have been pissed, good call but that is something I would remember , well , I would think I would remember, hic hic
This does seem pretty weird I reckon. If they had already told you about the turbo, why bother writing you an email to "remind" you. Oh well, it's all done now, enjoy it for what it is :)
If most look a bit deeper the truth is quite obvious, you didn't have to be Nostradamus to worked it out 30 pages back. Nothing has changed in 15 years of forum garage battles. A shame really.
But what's important is Pete gets his car back and is happy with it.
I remember reading an article and an english guy built a RIPS RB30 in a R33 with a PPG Getrag 6Speed they detuned it to 700HP as the torque smashed the gearbox to peices after a launch down the strip.
Was on pump gas too.
So have fun hahahaha with that monster and that insane torque number. Think there are reasons AMG also electronically limit their torque numbers :P
You are right, they just bought the Turbo thing up AFTER I posted pics of the cracks in the manifold and 6boost, I was surprised to get an email from them,
Matters not, I have not stopped smiling since I got the Dynos and could see the car is running much better, even at my piss stops through the night I had a smile :yes:
Vids, what sort of vids can I do, Dyno tunes are boring , see if I can get some tyre action if my drive line and AD08Rs let me without leaving the box behind :bomb_ie:
Well , thanks, I think lol
I will see how it feels and go from there, it will be interesting to see how it feels to drive instead of looking at a Dyno graph, about 700rpm earlier full boost,so see if it gets it going.
The tractive effort/torque is 974Nm , peaking at 5250rpm
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
