And that's why you v the cam
haha, you got it Pete
Should pick it up on Monday, busting to drive it back home and then the other crap starts with the old builder to sort out the leak problem that cost me heaps of $$$$s , plus had my car off the road for 7 months
I cheated and had a look see when I was at the house of jez last time
  • Like 1
Definitely flattened out that bottom end nicely would be mad to drive.
Do you think the 14 kilowatts was lost in the lack of lift in the intake camshaft?
I'm assuming you had the same size lift intake and exhaust on the old Dyno run?
I had the UE 260 10.8 cams with a sharp ramp rate, left the exhaust cam in
I was playing around, lol It is now a V-Cam Step 2 , 262 x 8.7 intake cam and using the same UE exhaust cam 260 x 10.8
Lost a little up top due to the smaller intake cam, would love to be able to use the 260 10.8
After waiting for months to find and start fixing the water leak I had too much time on my hands and thought , since the motor is out and the car was going to be in the shop for a while, I had plenty of time to order the V-Cam and get all the bits ready to plug in when it was going back together.
All run in and just about ready to go, couple of days to tidy it up :)
Pink old setup
Red vcam on
Green vcam off
Once Jez finally got the motor back he just got stuck into it :yes: this bloke is tops :wub:
  • Like 1
Was 8.7mm lift the biggest lift you could use?
You can get the "Pro" kit which has a 264 @ 10.0 mm but the price jumps up by another 50% or so. It comes with an ECU (which you cant option out) that you pretty much throw in the bin.
Worth noting is the little difference in power when going from a huge lift intake cam to almost an oem std spec intake cam, despite the slightly longer duration.
I agree and there where lots of things I could have done to make more power up top, bigger turbo and injectors were needed if I wanted to do anything as they were close to maxed out before the V-Cam and if I used the Pro I would have had to change them to get the benefit of the 10mm lift, I will never know ?
Photo of it being finished off. I even had strife with rocker the covers , waited forever to get them powder coated and when they arrived they were dinged :(
The Step Pro gives you more up top I think with the higher lift but only gives 300rpm over the step 2. Both give you a variable amount of 50deg. I was only after a better bottom end I went for the Step 2 and a lot less expensive.
It was hard to find out anything about V- Cams , so I had to wing it, bite the bullet and do it.
Paul might be coming up here at Easter and he can give an independent assessment of how it goes, just have to stop him and Mick-o from smashing the box,lol
  • Like 1
Good that you can finally drive it now after all this time[emoji106]
Cas is in the fully advanced position, was the ecu's timing locked and base timing set correctly prior to tune?
Edited by mr skidz
Cas is in fully advanced position, was the ecu's timing locked and base timing set correctly?
I bet my nuts it's set correctly.
Tuners do that so peanuts can't advance the timing by rotating the cas.
  • Like 2
Oooo I will be at Jez's Monday Pete, hopefully will see you there! I saw the Vcam ages ago but had to keep my mouth shut haha. Looks like you finally got the results you deserves right from the start! Shame you had to go through so much bullshit to get there.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
