What's with the bonnet margins Bob, poor bodywork or did he forget to close it.
No....... Just a sh!t fit!
EVERY importer says the same thing........ "We get everything checked out blah blah blah"......
They can't even align the bonnet. So yes at best a respray and worst who knows.
Bob.
true Bob
Drivers door doesn't sit flush when closed, bubbles in the dash.
"We import the best available" " You can Redline and it wont blow up "
Sure ?
Be a fair few of the pre 90's in the US of A rebuilding engines and replacing oil pumps and extending sumps.
Taking marketing lessons from Edward Lees huh?
I'm sure the Japanese will only sell them the best examples!
Perhaps we can expect a busy influx of North American SAUers?
I think I should dust off my welcome mat!
Anyone here need to sell spares across the Pacific?
Japanese Classics is probably the best importer when it comes to marketing right now since they have this and they sold an R32 to a writer for Jalopnik. I know they've had plenty of satisfied customers but saying they only bring over the best is marketing BS and anyone who just swallows that drivel here in the US is getting set up for disappointment. The truth is, because of the 25 year rule, we're basically scrounging for the leftovers at this point. There are still some nice R32s out there but most will need restoration to some degree and parts aren't "just around the corner" like this video says. I've been able to get the parts I need but I've done a lot of homework and talked to a lot of people to do so.
I'm seeing a lot of guys here in the US buying or wanting to buy these cars and I'm not sure all of them are informed enough about what they're getting into and this video doesn't help. I bought my Nismo knowing I'd have to do some restoration and with the full intent of doing so. I think a lot of buyers may end up just being overcome by nostalgia and then find out later it's not easy owning a JDM car never sold here in the States, especially one that's seen 25 years of use (and abuse in a lot of cases).
Looks like a crappy flimsy aftermarket bonnet, probably some bad fibreglass copy. Otherwise pretty standard cheap auction car LOL
Lets hope a bunch of imported 32's don't start showing up at all the "stance" circle jerk events, hardparked with airbags and wheel poke
A few random things.
1. If you had have seen the rubbish that was imported to Straya under the 15 year rule (1989 & a few 1990 model R32's) you would have a healthy scepticism for anything that is left. To be honest I don't know whether or not we got all the crap ones or just all the 89 MY 32's that were ever built. If it were me I would wait for a 1991 version as supply will increase greatly I would have thought as they were mostly not allowed to be imported into Oz.
2. Parts are pretty easy, all things considered.
3. Nostalgia is most of the reason for owning an old car. Most old cars are never restored properly - R32 being no exception.
4. Most cars ont he internet look better than they do in real life. It is only by owning something that you get to know its faults down to the tiniest missing nut, bolt or washer. This was reinforced to me when the owner of a car I thought was the business said of an oil leak "It was only the old dipstick being pushed out of the holder". Well that is ok then. May need to reconsider my position in the whole stand up shouting match I had with my ex engine builder about that very thing.
  • Like 1
Very true....... Not too many people know this.
Due to the Australian delivered cars being sold at the time, R32 GT-R's built between July 1 1991 and June 30 1992 are prohibited imports.
I wonder how many have come in over the years to end up as expensive track cars?
Bob.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
