On 22/08/2020 at 10:16 PM, Dose Pipe Sutututu said:
So PPG then?
PPG > Swimming Pool
Inb4 Brett decides to get himself a swimming pool.
Inflatable swimming pool that it is.
  • Haha 2
53 minutes ago, r32-25t said:
Just some progress pics after removing the clutches out of the drum 76D98F9C-521D-48A3-B98A-D5D73B618367.thumb.jpeg.9027374b1aac905e3d6ef9ada642abe1.jpeg10101969-D09C-4416-989A-F719FAAF9139.thumb.jpeg.6cfcf5239f05db8077ac71f0a4fb1f94.jpeg
12 thin clutches and two thick clutches or I'm all wrong with that part?
I decided to do a 9 plate set up in the drum for the transfer case and did the required measuring for the clearance. I only needed to go up one plate size and lucky for me Ben @BK had one in his collection and was nice enough to sell it to me.60D38398-8F3F-46BC-8FF6-E99AC9129ED5.thumb.jpeg.708d11e3a3cf79e6904a13dd59d380d7.jpegClutches in the drum ready to go E9E21918-7521-466D-B30C-270D11F20150.thumb.jpeg.a25f0fc78c6cc62d1006ded487e600e7.jpegThen fitted all the chain and sprockets back inDFF1ED7E-726D-4349-926D-28C6162E8103.thumb.jpeg.387dcae390cab7679e9f93b0dbbfc07c.jpegand the case all back together with new seals, orings and new oil filter, it’s all ready to be fitted to the gearbox (just need a gearbox now)
just like to say thanks again to Ben for all the advise and selling me the plate can’t wait to drive it
  • Like 2
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
