Just now, r32-25t said:
Hahaha that will never happen, way to many people with way more money then me
Just add heaps of nitrous.
Before you do that, make sure your ring gaps are good first.
13 hours ago, Count Grantleyish said:
Just add heaps of nitrous and a Samsonas
Hypertune catalogue, billet dis dat
How can I buy any of these things you keep recommending when you won’t even fit it to your own car
  • Haha 2
Well you have a Kebabtech 2500 do you not? :D
  • 2 months later...
With gtr fest and 2020 done and dusted now is the time to start removing parts that are being replaced.
first cab of the rank is the frenchies twin in tank kitF38C0213-397D-49E3-8D54-DF86F1175FFA.thumb.jpeg.02b9aeb5aa185cf738cb3b6f0c7d9a55.jpegfirst I fitted a 460 into the original cradle and put it back where it lives in the tank
then I modified the original top hate to take -8 and put some wire through that can hold some current and sealed them with some fuel resistant epoxy 5E28E925-ACEA-4FCF-B979-EDA896CBAB24.thumb.jpeg.9ccc3c57ef8e4b64bf4edf6ebcbc26f0.jpeg
  • Like 1
Hi mate. Replace that shit ASAP. Please tell me you never used the factory return line, as it reduces down to about 4mm in the cradle, not the best to be honest. That is way too close for terminal separation when pumps fail. Could've been done much better in the wiring, just glad it didn't fail on you.
Aren't you going a surge tank ? Why the FPG twin in tank setup, when the single FPG top hat will be sufficient when running external pumps from a surge tank ?
  • Like 1
Sorry only just saw this, I had the frenchys in tank twin set up with -8 feed and return lines and just removed it to fit a single pump back in.
ive modified the factory hat to take -8 feed and return hoses to a surge tank that I’m waiting to arrive and that’ll have twin pumps in it.
I wanted the factory hat back in for the fuel light to work again and the gauge to read like factory again.
The return port doesn’t connect to anything inside the tank it’s just open and pours straight into the tank
Running wires through the lid like that is a bad idea. They aren't properly isolated from the fuel, and fuel can get up and out of the tank through the wire. It's like you have glued a straw in (the straw has a wire in it so not as bad)
You wil notice your tank won't pressurise, meaning there is a leak.
Also - what fuel resistant epoxy are you using? Epoxies are generally not fuel resistant long term, you need a specialist epoxy like a phenol novolac for that. They also don't bond well to that sort of plastic, so you're going to have it shrink and pull away from the plastic fuel lid.
We have a modified factory top hat too in the white 32 with 3 x 6mm bulkhead fuel pump electrical terminals, an8 feed and return bulkhead fittings, factory sender, factory fuel light sensor. It's tight. It had a twin Walbro 460 setup in the factory pump cradle and revised it to go back to a single Walbro 525 in factory cradle. We feed the return in the tank back into the factory pump cradle with a 3/8" submersible gates hose.
I saw you were looking for a factory pump sock - an aftermarket version which is identical is available from Taarks/EFI solutions.
What lift pump and twin feed pumps are you going to use ?
Regarding the FPG kit - shouldn't the fuel gauge read like factory as it is a 0 - 90 ohm sender just like the factory unit is ? I want to go to an Frenchy's top hat in my blue 32 and know the fuel light sensor you can raid off your factory setup, and integrate that into the new top hat easily. Just need to add one more bulkhead terminal.
Did you say you wanted to give me your FPG top hat ? 👍
man ben i seriously value your threads and information. I read lots when i can and you have answered endless questions for me. guys like us over here in canada would be stuck without great mates like yourself when it comes down to the nitty griddy stuff! cheers hope all is well mate with the cars, just got all my parts so will be throwing that motor together soon.
I ended up getting my hands on a factory fuel sock, the feed pump is a walbro 460 it was one of the ones from the frenchys kit.
    • 12+ months passed so they have no obligation to do a warranty claim. It leaked from the rear circuit. Front circuit was fine, but I tried many times to bench-bleed and in-car bleed (wasted 1L of Penrite racing brake fluid) to no avail. Threw my old BM50 or whatever the standard R32 GT-R BMC is, brakes went back to normal. So from my very limited anecdotal experience, I cannot recommend HFM, even though a lot of their products looks good. Just my experience (I have a genuine Nissan BM57 in a box waiting to be installed now).
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
