Just now, r32-25t said:
Hahaha that will never happen, way to many people with way more money then me
Just add heaps of nitrous.
Before you do that, make sure your ring gaps are good first.
13 hours ago, Count Grantleyish said:
Just add heaps of nitrous and a Samsonas
Hypertune catalogue, billet dis dat
How can I buy any of these things you keep recommending when you won’t even fit it to your own car
  • Haha 2
Well you have a Kebabtech 2500 do you not? :D
  • 2 months later...
With gtr fest and 2020 done and dusted now is the time to start removing parts that are being replaced.
first cab of the rank is the frenchies twin in tank kitF38C0213-397D-49E3-8D54-DF86F1175FFA.thumb.jpeg.02b9aeb5aa185cf738cb3b6f0c7d9a55.jpegfirst I fitted a 460 into the original cradle and put it back where it lives in the tank
then I modified the original top hate to take -8 and put some wire through that can hold some current and sealed them with some fuel resistant epoxy 5E28E925-ACEA-4FCF-B979-EDA896CBAB24.thumb.jpeg.9ccc3c57ef8e4b64bf4edf6ebcbc26f0.jpeg
  • Like 1
Hi mate. Replace that shit ASAP. Please tell me you never used the factory return line, as it reduces down to about 4mm in the cradle, not the best to be honest. That is way too close for terminal separation when pumps fail. Could've been done much better in the wiring, just glad it didn't fail on you.
Aren't you going a surge tank ? Why the FPG twin in tank setup, when the single FPG top hat will be sufficient when running external pumps from a surge tank ?
  • Like 1
Sorry only just saw this, I had the frenchys in tank twin set up with -8 feed and return lines and just removed it to fit a single pump back in.
ive modified the factory hat to take -8 feed and return hoses to a surge tank that I’m waiting to arrive and that’ll have twin pumps in it.
I wanted the factory hat back in for the fuel light to work again and the gauge to read like factory again.
The return port doesn’t connect to anything inside the tank it’s just open and pours straight into the tank
Running wires through the lid like that is a bad idea. They aren't properly isolated from the fuel, and fuel can get up and out of the tank through the wire. It's like you have glued a straw in (the straw has a wire in it so not as bad)
You wil notice your tank won't pressurise, meaning there is a leak.
Also - what fuel resistant epoxy are you using? Epoxies are generally not fuel resistant long term, you need a specialist epoxy like a phenol novolac for that. They also don't bond well to that sort of plastic, so you're going to have it shrink and pull away from the plastic fuel lid.
We have a modified factory top hat too in the white 32 with 3 x 6mm bulkhead fuel pump electrical terminals, an8 feed and return bulkhead fittings, factory sender, factory fuel light sensor. It's tight. It had a twin Walbro 460 setup in the factory pump cradle and revised it to go back to a single Walbro 525 in factory cradle. We feed the return in the tank back into the factory pump cradle with a 3/8" submersible gates hose.
I saw you were looking for a factory pump sock - an aftermarket version which is identical is available from Taarks/EFI solutions.
What lift pump and twin feed pumps are you going to use ?
Regarding the FPG kit - shouldn't the fuel gauge read like factory as it is a 0 - 90 ohm sender just like the factory unit is ? I want to go to an Frenchy's top hat in my blue 32 and know the fuel light sensor you can raid off your factory setup, and integrate that into the new top hat easily. Just need to add one more bulkhead terminal.
Did you say you wanted to give me your FPG top hat ? 👍
man ben i seriously value your threads and information. I read lots when i can and you have answered endless questions for me. guys like us over here in canada would be stuck without great mates like yourself when it comes down to the nitty griddy stuff! cheers hope all is well mate with the cars, just got all my parts so will be throwing that motor together soon.
I ended up getting my hands on a factory fuel sock, the feed pump is a walbro 460 it was one of the ones from the frenchys kit.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
