On 23/02/2021 at 9:17 AM, Dose Pipe Sutututu said:
works fine with a lift pump
As long as the stupid 5/16" inlet / outlet hardpipes are removed, as this really is the entire problem with the factory GTR top hats.
  • Like 1
They’re gone, is -8 now
Yeah I saw. 👍 These factory 5/16" OD hard lines have cost me 3 x cracked fuel tanks from pressurisation with a surge tank setup. Not to mention never, ever use the R32 fuel pump cradle return line to put fuel back at the pump - it goes to about 4mm.
Bin it.
  • Sad 1
Yesterday I finished work early and decided to play with the car for a little bit, was just going to drain the oil and water and pull the gear stick out, next thing I knew the gear box was on the ground (well on my arm which was on the ground) and most of the engine was undone B95609D8-9DA1-4F96-81AD-B862782ADBE2.thumb.jpeg.7013e83eca463371f29998f20f5ff3ca.jpeg259C7551-5656-4717-8527-243EB4CF373E.thumb.jpeg.059d269ca284ce309c4736c23b70b931.jpeg
  • Like 2
Last night I wasn’t sure if I had done some serious damage to my arm or not, I woke up this morning at it was still sore but still able to move it so guess it’s ok.
today i decided to take an rdo cause I was super keen on getting work done on the car, I pulled the clutch off, pull the front shafts and undid the mounts and pulled it out and threw it on a stand 124A8802-A101-4A19-A112-EC2F017459EC.thumb.jpeg.67936a22a6314fbcda169e8fb85be538.jpegthat engine bay is a mess, I plan on fixing that while the engine is out
E2C7C9A2-AB33-4A0F-8A4A-91FA8A398835.thumb.jpeg.b74db927199892550ff30ed65f1d0db6.jpegReady to start stripping it down
  • Like 4
Started pulling the engine down today and everything looks clean without any sludge and etc, got the head off and after you turned the gasket over you could see the gasket had blown between 6 and the exhaust side water gallery.
Unfortunately that turned out to be the least of my problems and so far I’ve found 3 cracks in the deck of the block between 2 of the head bolt holes and water jackets so it’s a bin job and the search begins 😞91C7C94F-328C-4A38-9F9B-6EFE092FAD51.thumb.jpeg.7371cc8cf57351daf9a64443458984bc.jpeg42C3225D-5A21-4245-A784-E2CD38E68CAC.thumb.jpeg.8ffd7ac1039faf86f3f28a049f8a5893.jpeg
  • Confused 1
  • Sad 3
1 hour ago, Dose Pipe Sutututu said:
You want a RB25DET NEO AWD bottom end? has CP pistons in it and Manly rods, ARP mains, ACL race dis dat.
Apparently Hermit at PRP reckons its strong.
Herd some of those 23u rb25 blocks are bettter then 26 blocks in terms of strength and thickness etc
Has it been bored?
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
