On 30/07/2021 at 5:42 PM, r32-25t said:
Bay got blasted today 7D44A096-0B5B-4B47-9DD1-BEC7ECD53BF2.thumb.jpeg.0a273f55f37bc2a048de99fb81ccec26.jpeg
gets etch primer tomorrow and then paint during the week
Nice!  Are you going to do any hole deleting or rough area smoothing or just lay the paint on as is?  Either way it will look stunning once it's done!
  • Like 1
They are going to replace any of the seam sealer that’s damaged and a couple of little thing and then leave the rest of it how it is and paint it the same as the outside
  • Like 1
On 16/07/2021 at 5:37 PM, r32-25t said:
all ported and the chambers opened up and all the good bits fitted and valve clearances set
Curious on why you removed the squish pad?
Squish pads produce;
  • A required (read as "desirable") amount of turbulence in the mix right at the end of the compression stroke. This greatly improves mixture distribution and mixing at the point where it is getting ignited, leading to obvious desirable improvement of pretty much all the combustion parameters of interest.
  • A reduction in the surface area of the head and piston facing the flame at and near the moment of ignition. The tiny little volume of mixture trapped in there is a better compromise than the otherwise exposed but narrow corners all the way around the rest of the combustion chamber where it meets the edge of the piston. Small combustion chamber volumes and decreased surface area should cause improved resistance to detonation, rather than the commonly held opinion as expressed by R32-25t above. Which is not to say that once the usage of the engine is pushed waaay beyond where the OEM engineers expected it to be, that perhaps the hot edges of the squish pads do trigger detonation.
I'd be willing to believe the improvements in ignition triggering, ECU accuracy/speed and fuels (ie E85) have probably exposed the old belief as being more of a band-aid for problems with real causes elsewhere.
  • Like 2
On 03/08/2021 at 11:52 AM, r32-25t said:
As Paul said can of worms but by removing the squish pad it allows you to run much higher compression ratios without detonation becoming uncontrollable
I know it's a touchy subject, however just really curious to hear other people's thoughts on this.
My thoughts + most of these cars are running E85
The main issue was that in the past people threw on thicker than OEM head gaskets to lower the comp, at the same time without really thinking about increasing the squish area/volume as a by product of the thicker head gasket. This would indeed cause those undesirable outcomes with pre-ignition and hot spots.
There are argument for and against removing them, everyone’s option will always be different. The cars I’ve seen with them removed seem to make more power which says they have better flow.
the engine is not going to be a low comp dog, it’s compression ratio is going to be well above the factory 8.5:1
  • Like 1
Not related to the squish pads. Different things.
If that's in reference to what Dose said about thicker head gaskets, then also missing the point.
'Twere me, I'd be looking to increase the amount of squish in a modern engine build. Not decrease it.
  • Like 2
https://en.wikipedia.org/wiki/Pent-roof_combustion_chamber
Faster burn time, by introducing turbulence at the top of the stroke thus improving combustion
Designed by the frogs
From my understanding most modern engines run them
Why do people remove them.....??????
because it "can" lead to heat spots forming and pre-ignition happening, however this generally due to running thicker head gaskets to lower the comp for big boost.
Very 1990s way of tuning, nothing wrong with it but with E85, ECU and injector tech these days you would think there's no need to lower comp.
Yeah, to me it seems that removing them is removing an engineered design for better combustion
Is it a proven thing that they are the real cause for "possible" detination when running 98
Or is it more a thing when running on the ragged edge of a good AFR?
To me, the sharper edges on valve reliefs would be more of a place to propagate hot spots and det???
  • Like 1
Calculate the chamber volume and have pistons made to suit the increase in chamber volume to hit the target comp ratio.
I took the intake squish pad out when I built my head 10 years ago. 9.0:1 comp. Right or wrong thing to do, unsure. It’s hardly turned it into a dog though. 🤷‍♂️.
Interesting topic and one that never comes to a black and white answer.
  • Like 1
Sounds logical
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
