Without a house on it?
How would I have a whole years earnings if I striked for 265 days in a year...?
The money you earn over the whole year on the days you work = whole years earnings.
News reports actually celebrating the high prices Chinese are paying for Melbourne properties; anticipating huge prices will be paid at auction on the 8th of the 8th. Sell your city and your future morons (I'm looking at you Simon).
Think I might move to a city with less Chinese people, like I dunno, Hong Kong?
I'd love to test your morals if you were offered > MV for a property you owned birds
I'd do the same as the rest of these fgts
Like online buying from overseas
Government needs to step in here
Damn I wish I bought CBA shares at $28 :/
We have heaps of ex CBA staff that worked there then and were given heaps of shares.... bastards
I sold 550 of them Dec last year heh think like $85 each.
Got them bout 17 years ago from like a grand or something grandma left me (well dad did on my behalf) / built them up a bit and they kept building as well but sold to help with house deposit
Edited by UNR33L
Are DC even popular for shoes or clothing? Or are they like energy drinks where they just sponsor extreme sports and somehow get by on that?
Also why is he wearing bike gear? Curious to know how many bikes were destroyed.
I concur re: Win10.
As far as upgrades go, was really pretty seamless.
Also, legitimate for $0.
i did upgrade then a fresh install so it'd be activated still, no 'dirty' old data for me!
also s6 edge is awesome
Edited by UNR33L
  • Like 1
Whats the process for a clean install, I'm currently running 10 after the smooth as silk upgrade from 8.1... but what about if I need to start fresh? I've got no licence keys etc
after you upgrade from 8.1 it 'converts' your 8.1 key to a 10 key and activates to your device, so if you want a 'clean' install you can just burn the ISO to DVD or USB and boot off it as you normally would, then skip the part where it asks for your license key, once you get into windows it'll already be activated as it's the same computer
so yeah its basically 2 stage process, upgrade > then fresh install
Edited by UNR33L
And what if you replace the hardware of your computer? What do you do then?
DC is still massively popular with the kind of people that drink energy drinks every day.
It was originally a skate shoe company owned by Ken Block which is how he became a driver.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
